| Home > Help Needed / General Tech Chat > Cam timing OK? | |||||||
244 Posts Member #: 34 Senior Member |
16th Mar, 2005 at 07:50:48pm
Just measured my cam timing to be 106.5? |
17th Mar, 2005 at 11:25:58am
106.5 is a bit earrrrly...................
Edited by BENROSS on 17th Mar, 2005.
1171 Posts Member #: 107 Post Whore Sunny Sussex |
17th Mar, 2005 at 12:29:48pm
not use 1.5's with a phase2? Bugger.
17th Mar, 2005 at 07:56:23pm
Not the end of the world mike, rockers are easy to change, and easy to sell as all the NA mini boys want them!
17th Mar, 2005 at 08:25:56pm
it's best to do tests, with it as is and with it in a diffent place, as what should work doesn't always! Best 1/4 mile 13.2 seconds @116 mph
17th Mar, 2005 at 08:38:06pm
Mine deffo made more power with the 1.5, but at the expense of drivability lower down... I like the higher lift 'area under the curve' from 1.5 rockers however, so i'll be keeping 1.5's when I swap the the MG/kent 500 cam. On 17th Nov, 2014 Tom Fenton said:
18th Mar, 2005 at 08:49:53am
i would go with miniwilliams on that one, try it out i may work well, as with all tunning you never no as all engine specs are different so one engine may like 110 but another may like 108, but you never no unless you try it.
27th Mar, 2005 at 09:46:55pm
avonbar's sheet with the phase 2 said 1.3 rockers, shall i sell my 1.5's and go for 1.3 or will 1.5 be just as good/better or possibly worse?
27th Mar, 2005 at 11:42:27pm
me personally! mike i would use 1.3s ratio
28th Mar, 2005 at 07:28:03am
seems to be the single bigest wear probs on all engines when using 1.5 rockers, knackered lobes and followers always looking for them bigger bunches of bannanas |
