Home > General Chat > wondering how good diesel is in a parts washer?
I will end up using paraffin like others do, but i have 10 L of old diesel here in a can and wondered what that would clean parts like, any one use diesel in theres?
Pauly
Member #: 9045
Wolverhampton, West Midlands
I used diesel to clean my gearset and gearbox out with. Have to say its just as good as any other parts cleaner/paraffin.
I just poared some into a tupaware box, paint brush and away i went.
After cleaning with diesel 2 or 3 times:
Edited by Pauly on 14th Mar, 2011.
Hi Paul, yes i have to agree that looks a cracking job really clean!, thanks for letting me know.
Thats not clean *tongue*
10 minutes in a hot spin washer at the machinists I uses and its CLEAN
Diesel is a bit smelly for a parts washer would you not think? What do you clean the deisel off with?
Edited by Sprocket on 14th Mar, 2011.
Yoshimura
Member #: 9204
Amsterdam...Edinburgh
hey gents, i use kerosine to clean parts....bought a small ultrasonic cleaner (is normal for jewels)
in Lidle.....filled it up with kero....brilliant.....if you want a ultrasonic cleaner for your stuff see flee bay
Pauly
Member #: 9045
Agreed, its not 100% clean but better than it was, end of the day I wont see it so didn't want it too shiney. It is smelly but so is paraffin and some other cleaners.
not sure how the pump would like running with diesel?
Diesel does a good job of cleaning, but leaves an oily residue, and STINKS!
i can see an ultrasonic cleaner would be the tits, but i don't have one sadly:(
Sprocket 'What do you clean the deisel off with?' I never have to clean off diesel so i can't answer that mate.
O yes Rob i better read the destuctions!
Not sure how much the smell would both me, as only part on the mini so would be out side any way, good thinking though.
*Yes*
chinlesswonder
Member #: 1192
In the garage......again!!
i use a combination of parafin and diesel, i'd rather smell the parafin over the diesel anyday. I run the parafin through a paper filter before use, i tend to find it slightly gritty but suppose it depends where you get it.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
jamie@thefatgarage
Member #: 9345
Sheffield
My parts washer gets topped up with all sorts. It's always 1/2 empty when I need it, so I chuck in whatever is about. Diesel, paraffin, petrol, gunk...
Probably best not getting too close if you are a smoker.. or have rivets in your jeans, or breathe...
Star Mag
Member #: 375
Leicestershire
Best thing i have found for cleaning gearbox casings is alloy wheel acid! Works a treat.
As for diesel rather you than me it stinks!
Out of interest....what about fire risk ?
Is normal parts cleaner as flammable ?
our parts cleaner fluid is water based i think
Try and set fire to diesel, bloody damd difficult
I know any degreasers Ive used before are water soluble. Which makes parts very easy to clean in the washer, then simply rinse off afterwards.
chinlesswonder
Member #: 1192
I reckon good old parafin, kerosene, diesel etc is great for really dirty, ground in crap like suspension parts and bits covered in road dirt. The water based cleaners are good in a clean parts washer only, things like engine,gearbox etc.
thats cleaned in the bath with water based cleaner by swarfeger
brill stuff fooks up your skin though i would have though excellent in a parts washer*happy*
evolotion
Member #: 83
Glasgow, Scotland
our parts washer has a kinda wax-stat in the lid so if it catches fire the lid closes and starves it of oxygen, but saying that we fill it with water based stuff! i guess some parts washer fluids are very flammable.
Denis O'Brien.
Star Mag
Member #: 375
Leicestershire
We have a safety clean at work which is flammable I have set it on fire by accident with grinding sparks!
tadge44
Member #: 2500
Buckinghamshire
I would say if you have 10 litres of the stuff just use it.You can always get rid of the film with a quick splash of degreaser and the hose.
I can stand the smell of diesel and the oily film left is some protection from rust if you are not moving straight on to re-assembly.
hell Brett that's more like it!
well i have a wash today, and went for parafin in the end:) does the job ok, but that smells as well lol.
