Home > Wanted > 998 Con Rods
Anyone wishing to part with a set of early 998 A+ rods with the bushed little ends in exchange for some cash?
kenny2
Member #: 5362
wexford in ireland
wat year ya talkin??
On 5th Jan, 2011 wolfie said:
Can someone translate that *happy*
Early 998 A+, mid 80s at a guess.
The 99H/997 and some /B81 or /C20 had floating pins. All mine are 99H/E20 or later and have the press fit pins.
Edited by Paul S on 18th Mar, 2011.
kenny2
Member #: 5362
wexford in ireland
i've 80's metro engine and a 998 out of a designer.?? any use
Depends on the engine no.
However, I would not wish anyone to break an engine up just for a set of rods.
Anyone modified the press fit rods to bushed use? Or even just used the press fit rods with early floating pin pistons?
Can you not fit a bush into the normal rods and reem to suit?
Yes, but I don't have the machines to accurately bore the little end for the bush.
kenny2
Member #: 5362
wexford in ireland
mine are well broke i'll check l8r
I know your trying to help Paul so i really dont want to come accross as a cnut but please please dont use text speak, we are all adults on an adult forum and theres nothing more irritating than aload of text speak imo
kenny2
Member #: 5362
wexford in ireland
my apologies wolfie, i just do it out of habit as i'm sneaking inline in work so its quicker for me to do it and i'm less likely to get caught and in trouble,
kenny
I have two sets available. Though i am sure one set came from an 850. The other set deffo came from a 998 A+, but the 850 ones look visually much better.
£10 the lot plus post?
Usually the 850 ones have the pinch bolt little end, which is definately a no-no. You have a PM.
Sorru for being thick. Is bushed the floating type?
I have sets of both types I'm sure. But I use the floating so would have to tot-up my stock before letting any go.
Yes, bushed is the floating type.
Thanks guys, now sorted thanks to Sprocket.
one set deffo came out of an 850, however, the bloke I got the 850's from was a grass tracker, and the engines had been rebuilt at some point.
The '850' rods weigh in at a little under 700 grams and the 998 rods weigh in at a little under 670 grams. the '850' rods have a better cast finish on them, and the 998 rods have a rough cast finish on them.
How many sets do you want? :)
