Home > Help Needed / General Tech Chat > Brake pipe unions
jamie@thefatgarage
Member #: 9345
Sheffield
Simple one to help out the guy that usually builds cars from the wonderful metric world...
What size unions do I need on the end of the hard brake line that goes into the top of the single line larger tin brake master cylinder, and into the standard replacement flexible Goodrich hoses to the calipers and drums?
i'll hazard a guess at this one with 3/8"unf since I asked not so long ago about the rear wheel cylinders.
Easy to check this with the fine end of an old head stud
Edited by Sprocket on 20th Mar, 2011.
