| Home > Help Needed / General Tech Chat > ERA Mini Turbo - power spike | |||||||
45 Posts Member #: 9406 Member Tadley, Hampshire. |
22nd Mar, 2011 at 01:21:15pm
Novice here!
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
22nd Mar, 2011 at 01:26:00pm
that's a t3 turbo for you.....because i takes so long to spool, you need to change that to achieve smoother power delivery, suggest a quick search on gt17 "Cars are a lifetime of pain" |
22nd Mar, 2011 at 03:43:56pm
This is only a guess..... I remember reading somewhere about metro turbos running low boost (4psi?) until a preset rpm then it rises to 7psi..something to do with lowering the peak torque figure for gearbox longevity. Maybe the same is designed in to the ERA's. As for why the power runs out at higher rpm... no idea. |
22nd Mar, 2011 at 03:52:30pm
Check the hoses to your actuator and the boost controlling ecu, could be split/perished and not controlling the boost properly. On 11th Feb, 2015 robert said:
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
22nd Mar, 2011 at 04:01:30pm
Hi Rob! |
22nd Mar, 2011 at 04:39:36pm
It's the 'ecu' that operates a solenoid to switch the boost from 4 to 7psi.
In the 13's at last!.. Just |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
22nd Mar, 2011 at 06:32:18pm
If you want to keep the major parts original and achive a smoother power delivery you could disconnect the "ECU", and run 4psi or use a bleed valve if you want more. |
22nd Mar, 2011 at 07:39:22pm
Hi Alex - I am impressed you noticed!
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
22nd Mar, 2011 at 08:29:20pm
You can see if the actuator is doing it's job by disconnecting the boost solenoid. My first one had a weak spring and produced a huge spike of boost which then tailed off. However, those boost figures sound about right. The more worrying thing was that you said its detonating when the boost comes in.
22nd Mar, 2011 at 08:31:10pm
Also if the actuator hose was split you'll see a lot more than 8psi!!! |
23rd Mar, 2011 at 09:30:40am
I think perhaps spending a few quid on a proper rolling road tune might be worth it? It's not hugely expensive and is the best way to find any faults and get the most from the engine. I need to do that on mine when it's MOTed (haha! - like that's ever going to happen!) |
23rd Mar, 2011 at 10:38:50am
The mixture was good all through the test. The operator did say something about the rolling road being upset or confused by the severity of the spike.
23rd Mar, 2011 at 10:47:43am
To get 90odd bananas at 4800 would need way more boost than 4psi.
23rd Mar, 2011 at 12:36:39pm
I think your right about not getting boost before 4200 rpm.
On 23rd Mar, 2011 ricsdad said:
The mixture was good all through the test. The operator did say something about the rolling road being upset or confused by the severity of the spike. On reflection and having read all your comments (bearing in mind I dont know what I am talking about!) 60ish hp to 4000 revs is clearly with no boost at all, then the ECU trips in at 4200 and i get maximum standard boost 7.5psi. Now the rolling road printout says the power drops off - but driving it you wouldnt say that! So maybe the problem is I am not getting my 4psi to start with! The rolling road printout which I shall edeavour to paste up here later shows hp dropping after the spike - but torque continues - is that odd? The fear I have is getting someone to look at it who "says" they know what they are doing - but actually dont have as much experience as the lovely people in this forum! Just read the Rover Owners manual and it says "Smooth power delivery up to maximum boost 7.5psi at 6200 rpm! Now am I being picky expecting a 22 year old car to perform to Rover's claims!! Edited by almichie on 23rd Mar, 2011. On 7th Nov, 2011 apbellamy said:
23rd Mar, 2011 at 07:02:10pm
Well here goes!
23rd Mar, 2011 at 07:06:14pm
Hopefully this one will be bigger!
23rd Mar, 2011 at 07:36:19pm
very nice!
23rd Mar, 2011 at 08:05:55pm
Really this needs to go back on the rollers with someone who knows what they are doing.
23rd Mar, 2011 at 08:46:51pm
That looks bloody clean! |
![]() 825 Posts Member #: 2208 Post Whore Essex |
23rd Mar, 2011 at 09:15:39pm
nice, there lovley cars, classic! |
23rd Mar, 2011 at 09:16:17pm
have seen similar if the actuator is sticking, but tbo thats a wild guess, the car really needs to go infront of someone who knows there way about it. turbo 16v k-series 11.9@118.9 :)
23rd Mar, 2011 at 10:02:32pm
Did the ERA use the same boost modulation system as the Metro?
On 23rd Mar, 2011 Tom Fenton said:
Really this needs to go back on the rollers with someone who knows what they are doing. I would personally remove the boost modulation stuff and wind the actuator up to give around 7 psi all through the rev range. Then run it on the rollers and see what it does then. It may be something daft like the actuator has gone weak over time. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
23rd Mar, 2011 at 10:19:17pm
The ERA did use the same boost modulation system as the metro, but the ECU was modified slightly to give greater than 4 psi boost sooner (but still a maximum 7 psi).
24th Mar, 2011 at 07:39:21am
Interesting, cheers. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Mar, 2011 at 07:53:36am
i 'd agree with denis ,looks a lot like a sticking actuator .
