Home > Help Needed / General Tech Chat > another starter motor cry for help.. lol
wintersurferuk
Member #: 2208
right,
my car came off the road a few months back due to carb probs, now fixed.
starter was engaging with the flywheel, but very slowly. this was with two battires and a jumpstarter.
so, ive fitted a new starter motor. but now it wont engage with the flywheel, just spins.
tryed so far:
hitting the starter motor
new earth
pushing the car in gear, flywheel spins
sparkplugs out
pumping the clutch.
pr-verto starter, checked its the right one.
fully charged battery and jumpsrarter.
any other ideas i could try. going to tow it later and see if i can get it going that way. *oh well*
You aboput friday? I'm going to minispares so can drop in.
wintersurferuk
Member #: 2208
should be, ive got work at about 5 *oh well*
What type of starter is it, inertia or pre engaged?
wintersurferuk
Member #: 2208
it not a piggyback one, sorry not sure. sloidn is on the wing,
(sorry my spelling is so bad) :(
it's inertia. You need to whip it off and try it on the garage floor. Check the throwout throws out (by hand then when you spin the motor)
wintersurferuk
Member #: 2208
thanks will, i'll give it a go.
wintersurferuk
Member #: 2208
took it off, but not out of the car, throw seens to move freely.
how do i test it out of the car, ive put a tiny rub of grese in the thread to lube it a bit but still no luck,
can i stick a jump starter on it when its out the car lol
yes, jou need to earth the body and then put 12v to the terminal. stick it in a vice though or you risk it going dancing accross the floor
wintersurferuk
Member #: 2208
just tryed that, seems to work.
is there a knack to fitting them?
if not i'll tow it tonight!
I'll be passing about midday, PM me your adress (i'll never find it in the day light!) and i'll drop in.
wintersurferuk
Member #: 2208
thought i'll update incase anyone reads this.
my problem was an earth on the battery.
next problem is the flywheel has come free! lol
