Home > General Chat > Recomend me a rotary tool
mini_mad69
Member #: 7048
Bridgend
Im going to be buying a rotary tool for modifying my cylinder head. Things like opening chambers and ports etc.
Is dremel the best? Seems like the most recognised. This is for occasional use.
I bought one from lidl and it last 2 minutes before it shit itself.
Turbo parts collector at the moment, almost ready.
I've ruined 3 dremels now. Been using them for light body work - mainly cutting steel with the small cutting disks.
You'll be here till the next millenium trying to do any decent amount of work on a head with a dremel.
i had the black and decker version, lasted 5 years of general use, a bit of head work and 2 sets of rods saw it die
Dremels cant be used for anything other than 'light' work. You need a die grinder
I always assumed that head grinding was done with air-tools.
bigmini998
Member #: 2830
Costa del Northern Ireland :)
Air die grinder.. I bought a cheap one years ago. It's the most versatile tool I have. When I finish with 1mm cutting discs in my angle grinder I use them in my die grinder and get the same ammount of work out of them again
That mini is determined to Kill me!!!!
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
Axeminster power tools do a good die grinder for £20 but the stones that come with it are shit, buy some separate 60 grit stones and your laughing :) just take your time if never done it before and you will be fine
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
