| Home > Help Needed / General Tech Chat > More cam endfloat | |||||||
29th Mar, 2011 at 07:46:02pm
It seems I have no cam endfloat, so I made some 6 thou shims to put between the thrust plate and front plate just for measurement and 6 thou seems ok as 3 - 7 is standard
I seriously doubt it! |
29th Mar, 2011 at 07:51:42pm
Are you using the thin paper gaskets or the cardboardy stuff? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
29th Mar, 2011 at 07:52:06pm
Thin paper.
Edited by paul wiginton on 29th Mar, 2011. I seriously doubt it! |
29th Mar, 2011 at 07:54:16pm
the gasket shouldnt effect it,
Edited by Joe C on 29th Mar, 2011. On 28th Aug, 2011 Kean said:
29th Mar, 2011 at 08:00:25pm
29th Mar, 2011 at 08:02:32pm
On 29th Mar, 2011 Rod S said:
Beware of thinning the triangle, one side of it is whitemetal faced..... Unless you get a shit cheap one... On 28th Aug, 2011 Kean said:
29th Mar, 2011 at 08:02:55pm
The issue is no float before the sprocket is fitted which is why I was thinking a thicker gasket to space the front plate from the block and cam I seriously doubt it! |
29th Mar, 2011 at 08:06:24pm
Ah,
29th Mar, 2011 at 08:09:12pm
Pretty certain its because the carbon front plate is slightly thinner than standard.
29th Mar, 2011 at 08:17:00pm
Ah! non standard parts!
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
29th Mar, 2011 at 11:36:56pm
I've got the same issue with my med alloy backplate, yes you need shims between backplate and triangle to the required end float. Class C 3rd Place Avon 2011 14.18 @101mph |
30th Mar, 2011 at 08:22:47am
You only want to brag about your carbon front plate Edited by Vegard on 30th Mar, 2011. On 13th Jul, 2012 Ben H said:
30th Mar, 2011 at 05:09:15pm
If I slim down the thrust plate (triangular thingy Vegard) it will make no difference at all as it sits hard against the cam I seriously doubt it! |
31st Mar, 2011 at 08:23:51am
Maybe a bodge, but two gaskets under the front plate (or make a thick one from scratch)?
Edited by graemec on 31st Mar, 2011. |
31st Mar, 2011 at 09:00:25am
Yes Paul, but it's the clearance between the cam and cam drive that determine the endfloat right? Ok, so shims between the cam and the gear would obviously increase the endfloat. What makes you think you've got too little? If the cam turns will it lock against the oil pump when hot? On 13th Jul, 2012 Ben H said:
31st Mar, 2011 at 09:06:42am
On 30th Mar, 2011 paul wiginton said:
If I slim down the thrust plate (triangular thingy Vegard) it will make no difference at all as it sits hard against the cam That certainly implies the "thin" front plate is causing the cam to be pushed back against the oil pump and trapped. Have you tried loosening the oil pump bolts to prove it ? If it is just a case of moving the front plate further out, some of the non-genuine front plate gaskets are a lot thicker than the genuine ones - as I found out when I had to use a massive amount of shims behind the crank sprocket to get it far enough out to match. Schrödinger's cat - so which one am I ??? |
31st Mar, 2011 at 04:36:58pm
I put another gasket behind the front plate and its sorted now. I seriously doubt it! |
31st Mar, 2011 at 05:34:31pm
On 31st Mar, 2011 paul wiginton said:
I put another gasket behind the front plate and its sorted now. So the oil pump was the reason? On 13th Jul, 2012 Ben H said:
31st Mar, 2011 at 05:48:35pm
The oil pump and cam have not been removed from the engine. Im only replacing the front plate and timing gear with lighter ones.
31st Mar, 2011 at 05:48:45pm
More to the point, I thought you hated carbon fibre. In the 13's at last!.. Just |
31st Mar, 2011 at 05:53:09pm
Ive painted it green, you cant tell and it weighs less than 140 grams including the titanium studs and countersunk screws I seriously doubt it! |
31st Mar, 2011 at 05:55:05pm
Very fancy. In the 13's at last!.. Just |
31st Mar, 2011 at 06:01:55pm
Chances are the key slot in the gear is cut in a different place.
31st Mar, 2011 at 06:01:57pm
Why not slim down the triangular thingy?
