| Home > Help Needed / General Tech Chat > Shifter + Linkage in car - how? | |||||||
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
4th Apr, 2011 at 08:59:26pm
I want to do this, can anyone tell me how?
4th Apr, 2011 at 09:01:49pm
Welder, some uj's and a lot of mocking up, swearing, starting again and eventual success. On 7th Oct, 2010 5haneJ said:
![]() 100 Posts Member #: 4826 Advanced Member Isleworth |
4th Apr, 2011 at 09:05:38pm
KAD sell a direct replacement iirc, but cant see it on there site. |
4th Apr, 2011 at 09:07:06pm
On 4th Apr, 2011 racer_pete said:
KAD sell a direct replacement iirc, but cant see it on there site. As do force racing On 7th Oct, 2010 5haneJ said:
1083 Posts Member #: 8932 Post Whore |
4th Apr, 2011 at 09:09:14pm
If your clever enough you can DIY but as said KAD and Carl make kits. |
4th Apr, 2011 at 09:10:35pm
In that pic mate is the kit KAD sell. I have started posting on Instagram also my name on there is turbomk1golf
4th Apr, 2011 at 09:15:37pm
minispeed sell it, i was looking at KAD stuff earlier |
4th Apr, 2011 at 09:30:18pm
I had to move the handbrake lever back. That then posed the problem of the need for a shorter cable. I then adopted the solution from a friend, of using a rigid rod instead. On 26th Oct, 2004 TurboDave16v said:
4th Apr, 2011 at 10:20:37pm
i just bent my handbrake to one side :) , but you will have to learn a new way of releasing the hand brake as you will graze all the skin of your hand otherwise.
4th Apr, 2011 at 10:27:00pm
You can just see what i came up with for the handbrake.
Edited by madmk1 on 4th Apr, 2011. I have started posting on Instagram also my name on there is turbomk1golf
4th Apr, 2011 at 11:35:59pm
Is that just a little bracket to lift the front of the handbrake up simon? |
4th Apr, 2011 at 11:43:47pm
yes mate it was not hard. I have started posting on Instagram also my name on there is turbomk1golf
5th Apr, 2011 at 12:17:17am
Easy yes, but I questioned the reduction in lever action. I settled on moving the whole lot On 26th Oct, 2004 TurboDave16v said:
5th Apr, 2011 at 09:40:24am
Thanks thats good to know, i'll leave mine and do the same if necessary. |
5th Apr, 2011 at 10:19:43am
excellent, I'll look up the kits. thanks chaps |
203 Posts Member #: 479 Senior Member |
5th Apr, 2011 at 04:05:44pm
I've made my own, as my gear turret is higher and a little bit further back that where the kit put it.
5th Apr, 2011 at 06:37:03pm
http://www.force-racing.co.uk/engine/
Mr Gay UK said:
Internal gear linkage and tower, £140 This internal gearstick setup uses a lightweight ally tower that lifts the gear stick higher into a more easy to reach position, another benefit is that the origional stick can be shortened to suit individual requirements and as a result acheives a shorter throw for the user, Utilizes a single length adjuster on one end for fine tuning , coupled with precision UJ's held in place by grub screws , the origional gearstick housing simply bolts on using the thread s that hold the base plate in position , [ longer bolts supplied ], comes supplied with all nuts bolts and grubs needed to fit, Easy to fit, no welding on of brackets, simply bolts to the side of the tunner on later cars Isambard Kingdom Brunel said:
