| Home > Help Needed / General Tech Chat > Rust remedies. | |||||||
11th Apr, 2011 at 10:53:46pm
I guess this is as good a forum as any to ask given Mini's rust free bodywork.
11th Apr, 2011 at 11:10:54pm
http://www.machinemart.co.uk/shop/product/...ers-accessories
11th Apr, 2011 at 11:24:33pm
drill mounted wire wheel, from wilkos around 1.69 each and they last :) not as aggressive as the angle grinder ones but still work well enough Yes i moved to the darkside |
11th Apr, 2011 at 11:47:21pm
Cheers..thought about the drill wire brush thing, although not sure it will fit into some areas.
Edited by stevieturbo on 11th Apr, 2011. 9.85 @ 145mph
![]() 130 Posts Member #: 9395 Advanced Member |
12th Apr, 2011 at 12:27:24am
The problem with rust is that it leaves little pits in the metal work which sanding does not remove - the disc cannot get in to those little pits unless you sand to a degree where it thins out the metal to the bottom of those pits
Edited by ntm1275 on 12th Apr, 2011. |
12th Apr, 2011 at 07:21:06am
You cannot beat one of these for awkward spots.
12th Apr, 2011 at 02:14:00pm
On 12th Apr, 2011 ntm1275 said:
The problem with rust is that it leaves little pits in the metal work which sanding does not remove - the disc cannot get in to those little pits unless you sand to a degree where it thins out the metal to the bottom of those pits If you leave any of the pits, the rust will come back in no time The options are:- 1. grind or course sand until it's all gone 2. cut out the metal and weld in a new piece 3. use a needle scaler - but you would need very small needles to get in to the pits 4. blast the area with a fine grit (not sand, as it's too course) If it's a large area, it is better and easier to cut out and weld in a new piece, but if it's a small area and/or in an awkward place, blasting works very well I recently bought a portable blasting kit, and use a fine grade shot blasting material, and the results are fantastic - it will even blast aluminium without damage to the metal - the kit was only £40 and came with a drum, hose and gun, but you do need a compressor for it to work The blasting material can be used over and over again, as it doesn't seem to disintegrate much http://www.pvrdirect.co.uk/productinfo.aspx?catref=SB993 Here are some examples of what I've already done
The dark patches are caused by by dirty hands from handling it when it was covered in rust and grease ![]() Never even thought about shot blasting. And £40 isnt dear at all. What media does it use ? Does that kit come with stuff to use ? What about this soda blasting stuff ? Ive seen some people DIY with baking soda ? 9.85 @ 145mph
12th Apr, 2011 at 06:44:15pm
Soda Blasting is the 'in' thing these days On 26th Oct, 2004 TurboDave16v said:
12th Apr, 2011 at 07:20:03pm
What media does it use ? Does that kit come with stuff to use ? What about this soda blasting stuff ? Ive seen some people DIY with baking soda ? I used ordinary shot blast grit (also made by Sealy) and it looks like very, very fine grains of black grit, and it cost me about £12 for 25kg from my local motor factors If you want to save on the cost of buying more and more grit, use the blaster in an enclosed space, or a sectioned off part of a garage, because if you use it outside, the grit will travel a long way and you will loose most of it If used inside, you can sweep it up afterwards and sieve it before using it again and again So far I have used the 25kg bag about 15 times with minimal lost of grit, but it is starting to go finer and finer now Yes I would assume that you could use any form of blasting material just as long as it is fine enough to go through the nozzle of the gun When using it, you must have a decent air regulator on the compressor, as any moisture in the air line can cause it to clog the gun Safety wise, it is best to use some form of full face mask because the grit flies everywhere I tried it first with some goggles and paper mask, but soon changed as the grit was getting in through the small air holes in the side of the goggles, and inside the mask through the parts that were not sealed tight against my face You don't want the grit in your eyes or lungs For tight corners, or inaccessible places, it's a god send, as power tools just cannot get in there |
13th Apr, 2011 at 09:34:11am
Yip, I have a wire knot thing and learned myself wires tend to eject themselves into your face !!
