Home > Wanted > Thermostat housing with temp sender NEEDED!
jeffreypang911
Member #: 9074
I am looking for a thermostat housing with sender hole like so:
I believe on late Rover carb minis they also had the sender in the front of the housing.
Thank you
Jeff
Edited by jeffreypang911 on 17th Apr, 2011.
jeffreypang911
Member #: 9074
No ones got anything?
I have one from an automatic mini where the tapped hole is below the top hose outlet, is that any use to you?
I have one thats new with a temp sender in too.
EDIT: Thinking about it, its off my 850 lump so not sure if it'll suit a 1275 etc, if thats what its going on? Im not sure how the housings differ between blocks.
Edited by matty on 25th Apr, 2011.
turbominivanman
Member #: 1504
Westbury, Wiltshire
I have two stat housings.
One with the threaded sender hole coming straight out the top (Morris Minor I think).
The other has the hole coming out of the other side of the stat housing at 180 degrees opposite to the one in your pic.
PM me if you'd like either.
Richard.
