| Home > General Chat > is this anybody from on here? | |||||||
15th Apr, 2011 at 03:24:20pm
Just seen a mini some of you may know on the back of an aa van by prestwood averies near kingswinford. I saw it at minispares midlands open evening last year. As far as im aware it has a std metro turbo, vermillion red, roundnose, black grille, black 10" wheels and 3 swaged holes on the drivers side of the bonnet. Wonder whats happened to the fella :( On 26th Jan, 2012 Tom Fenton said:
549 Posts Member #: 5327 Post Whore Dudley, West mids |
15th Apr, 2011 at 04:02:23pm
Yep that's me. Started turning the boost up and blown the head gasket. Well at least i hope its the gasket. |
15th Apr, 2011 at 04:14:49pm
15th Apr, 2011 at 04:17:00pm
Will do. I'll start stripping it tonight after I've put my kids to bed. |
15th Apr, 2011 at 04:39:34pm
![]() 428 Posts Member #: 39 Senior Member Bristol |
15th Apr, 2011 at 06:54:19pm
Must get AA cover when the van gets on the road. hope not serious. |
15th Apr, 2011 at 09:29:12pm
Here was the problem
15th Apr, 2011 at 09:35:18pm
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
15th Apr, 2011 at 10:40:04pm
That's well fubard.
16th Apr, 2011 at 10:44:07am
you wer lucky. pre ignition sorted that for you. if you dont sort it, ie lowering th CR or intercooling it and or ignition advance, the next time will be the pistons melted
16th Apr, 2011 at 01:59:21pm
Blimey thats pretty extreme, check the block surface very very carefully before you consider putting it back together.
16th Apr, 2011 at 07:16:48pm
^agreed they tend to sink between 2-3 If something is worth doing, it's worth doing half of. |
16th Apr, 2011 at 07:24:54pm
16th Apr, 2011 at 09:49:25pm
Block and head are fine, and are still flat with no high or low spots.
16th Apr, 2011 at 09:53:54pm
Gents I have a spare gasket in my garage with bk450 stamped on it except it is grey in colour. I've only ever seen black ones.
150 Posts Member #: 8909 Advanced Member North Cornwall |
16th Apr, 2011 at 10:18:48pm
I did a head gasket like that after forgetting to torque it down for the 2nd time, won't make that mistake again If in doubt... flat out! The words of a true legend |
17th Apr, 2011 at 07:47:15pm
All fixed today and back together. Did a cool and hot compression check and equal across all cylinders. Hopefully I won't have anymore problems for a while. Fingers crossed. |
45 Posts Member #: 9406 Member Tadley, Hampshire. |
18th Apr, 2011 at 04:07:44pm
Are you sure that is pre ignition?? Looks like mice have been in there!!! |
18th Apr, 2011 at 05:35:15pm
Is that gasket made by Payern? In the 13's at last!.. Just |
18th Apr, 2011 at 07:46:18pm
Don't know what the make of gasket is. It's got the CP in a triangle and 'made in England' stamped into it.
