Home > Help Needed / General Tech Chat > Radiator Clearance issues
madonminis
Member #: 9371
East Yorkshire
Having just mounted my engine I have noticed that the front mounted radiator I got from an MPI mini catchs on the distributor and is also very close to the oil filter. Has anyone fitted this rad with the dizzy still attached? What kind of front mounted setup is easiest to achieve and such like???
Many thanks folkes.
I tried with the dizzy when the magajolt was playing silly buggers. Had to go back to the side rad in the end.
Gavin Wakely
Member #: 793
You can get a right angled dizzy cap that will give more clearance, Minispares used to sell it.
Many thanks folkes.
