Home > For Sale > MPi Radiator, intercooler, inline fan switch
MPi rad with around 1000 miles on it - £35 plus P&P - SOLD
The flies are free *wink*
MR2 Intercooler. The core is 250mm x 330mm x 65mm. Total width including feed/return tubes 340mm. Tubes are 50mm o.d. Helped the van run 150 bananas. With a bit of work this should go in a round nose. I can hack the original rubber mount brackets out of the front of the van if you want them. £20 plus P&P
In-line fan switch. Alu body, takes 32mm i.d. hose. On at 90 degrees and off again at 80. £10 plus P&P - SOLD
Edited by apbellamy on 21st Apr, 2011.
Funkyp
Member #: 9354
hi,
I am interested in the inter-cooler,
pm'ed you :)
Apparently, I'm Wrong :[
roofchoplofty
Member #: 9416
durham
Hi im interested in the inline switch, i shall pm you.
MPI rad please.
Fancying a bit of greatness from the Metty Van eh Mr F? *happy*
Argh no, I demand a discount.
Funkyp
Member #: 9354
Please,
You are in no place to make demands *Rofl!*
Do you want to pick it up Mr F or shall I call in later on?
On 21st Apr, 2011 Funkyp said:
Please,
That my friend is where you are wrong.
Andy no rush, what night are you in the garage I'll have a ride over.
I'll PM you.
EDIT: LMAO at Tom and FunkyP
All sold. Thanks
Intercooler is available again. Bloody Royal Fail!
tadge44
Member #: 2500
Buckinghamshire
Would you like to work out a swap for a set of A+rods Andy ?
That sounds like a good plan *smiley*
