Home > Help Needed / General Tech Chat > Suggestions, please.
tadge44
Member #: 2500
Buckinghamshire
My 1275cc engine is running 8.2:1 compression,MG N/A cam,GT1752 with MJ and an HIF44.
Presently, as I have just about completed running in, I am running 10psi with a max advance of only 20 degrees.
Thinking of running to 15psi, so how much more advance is safe, pending a RR session ?
I always use 24 as a safe value. Running 17psi on 8.5:1.
Quite good that wil. Bit more than I expected :)
bennyy
Member #: 9037
Doncaster, yorkshire
I have mine set at 25 degrees and use around 16-17 when needed.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
26 degrees here, running a minimum of 15psi and up to 20.
What CPR Phil?
8.3-1 mate.
The alloy head allows you to runa bit more CR.
The sprint runs 12psi CR 9.3:1 and max advance on boost 24.
tadge44
Member #: 2500
Buckinghamshire
Thanks everyone -looks like I can go up a bit in due course.
I reckon I will have to pull back the advance at lower revs as the GT17 comes on boost so much earlier.
Short road test today (with everyone else glued to the box) and it was still accelerating at 95 indicated,so looking for good things in future.
