Home > Help Needed / General Tech Chat > Clutch Options - Verto, Non, RTS or Otherwise?
carts60
Member #: 9335
Bromley, SE London
So my engine didnt come with any clutch parts at all, apart from the clutch cover and arm - picture at the bottom of the post.
So i'v been looking at all the clutch options but don't know what to go for. My build should produce about 120-130 bananananas.
What I really want to avoid is anything thats going to be heavy underfoot as the car will be used as a daily driver, or very regularly at least. Living in London, having a very heavy clutch will take any pleasure out of driving the car because traffic is regularly heavy.
If I go verto I could use a standard turbo clutch kit, but it would be right on its limit and would be likely to slip when I no doubt turn the boost up
The next level up would be to build an RTS clutch right? Can somebody link me to how to do that?
Pre-Verto, turbo-mini.com suggests going grey for an engine producing 130 hp but i'v heard that its quite heavy under foot, but will orange be strong enough?
I hope you can clarify this all for me as i'm undecided and confused as to what an RTS is.
What's everyone else running with similar set ups?
wez
Member #: 9271
Stoke on Trent
i believe this thread will start to explain the RTS clutch. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10207
have a search there's other threads about it too.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
eden7842
Member #: 8852
leicestershire
i believe an orange diapram would be up to the job there.
ive got one in my estate and its very good, but ive got a grey in the turbo and it sucks in traffic big time
I disagree. An orange is OK for NA engines as they don't make the torque. A turbo engine will overwhelm an orange with no problem.
carts60
Member #: 9335
Bromley, SE London
If an orange will be too weak and a grey too hard for traffic, whats the comprimise?
RTS
for 120 to 130 lbs/ft , id use a stock turbo pressure plate ,and a ap rally driven plate .
carts60
Member #: 9335
Bromley, SE London
Can you estimate torque (curleys right?) from nanas?
So if im aiming for about 120-130 nanas, what kind of torque output can i expect?
Is there any step by step guide as how to make an RTS?
Edited by carts60 on 2nd May, 2011.
andyuk1275
Member #: 9276
Darlington north east
lots of people are intrested in the rts idea now, someone who knows what there doing needs to make a specific thread on how to make one !!
its called 'clutch thoughts' and was starterd by the 'R' in RTS ( aka robert)
in the mean time me and John are working on a "how too" for those who cant fatham it out *wink*
Edited by Brett on 2nd May, 2011.
carts60
Member #: 9335
Bromley, SE London
Yeah i'v read clutch thoughts but im pretty technically clueless at this point in time. As much as i understand the principles I dont want to go bodging something up before I know its right.
Can't wait for the 'How to' Brett. How long do you think its going to be before its up?
hazpalmer
Member #: 9038
Carlisle, Cumbria
im interested in the RTS too, i have a rough idea but no enough to do it myself.
