| Home > 998cc > Manifolds not sitting flush. | |||||||
275 Posts Member #: 4600 Senior Member Melton Mowbray, <BR>near Leicester |
1st May, 2011 at 11:16:09pm
Basics specs:
1st May, 2011 at 11:24:54pm
This is quite a common issue.
In the 13's at last!.. Just |
1st May, 2011 at 11:26:14pm
Or use an MG Metro NA inlet manifold.
1st May, 2011 at 11:26:32pm
Yeah that was my initial thought! easy fix then.
2nd May, 2011 at 07:54:46am
I had the flange side of mine macined so the two flanges were the same thickness. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd May, 2011 at 08:18:48am
Could I take away some metal with my angle grinder where the washer sits, on the back of the manifold? |
2nd May, 2011 at 08:35:25am
Aluminium doesn't "grind" well at all, it just clogs up the grinding wheel. If you want to remove aluminium use a very coarse sanding disc on your angle grinder.
2nd May, 2011 at 08:43:07am
Hm yeah stepped washers seem the quickest and easiest option, I'll give them a go.
