| Home > Help Needed / General Tech Chat > NEW ISSUE Quick Electrical Question | |||||||
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
2nd May, 2011 at 03:11:43pm
I am converting my SPI mini to carb, i have found some decent instruction on minimainia. i have got a bit stuck wireing in a relay to replace the ecu. I know the pins i need to use by number but do not know where to start counting? i assume top left will be number one, but which way is up?
Edited by maccamcvey on 9th May, 2011. |
![]() 478 Posts Member #: 9269 Senior Member Rotherham |
2nd May, 2011 at 11:48:41pm
Don't know about the electrical plug but the fuel pressure will need to be about 3pis. I think the pump will need to be the type that turns off when the right pressure is reached if your not using a return on the reg.
Craig
3rd May, 2011 at 12:14:10am
Cheers craig i was going to start with a low psi but the pump just forced fuel passed the seals on the reg. so i am going to use a Facet pump i was planning on useing on my turbo build. as for the wireing with a bit of guess work the pump works but i am only getting a very week spark, not had much chance to look into this as of yet. the coil is hopefully to blame |
3rd May, 2011 at 12:27:22am
your regulator is bad then, a good reg shoudl get an injection pump down to 3psi no sweat.
3rd May, 2011 at 12:28:23am
oh aye, and you need to use a regulator with a return feed if your using an injection pump (just noticed that post, sorry) turbo 16v k-series 11.9@118.9 :)
3rd May, 2011 at 05:14:47am
Normal protocol with Ampseal connectors is No 1 top left but reading from the back of the plug (the side the wires go in) so would be bottom right in your photo.
3rd May, 2011 at 06:35:33pm
Plumb the fuel flow from the pump into the regulator inlet and the fuel return to the tank onto the regultor outlet. Tee into the fuel flow from the pump and connect that to the carb, set the regulator pressure to 3psi. Job done. On 26th Oct, 2004 TurboDave16v said:
9th May, 2011 at 02:01:29pm
Cheers for you help guys but a little more is needed.....
9th May, 2011 at 02:02:33pm
Is the engine earth good enough? Is the starter wiring pulling the 12v feed to the coil down somehow? Is it wired through some weird ballast system?
9th May, 2011 at 03:10:10pm
Fairly certain it’s not a ballast system but i could be wrong, not knowing a huge amount about the old spi wiring. Also the earth is good.
9th May, 2011 at 04:39:59pm
have you got a live feed from the starter solenoid that is live on cranking attached to the dizzy ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th May, 2011 at 06:03:23pm
I think the orignal live feed to the coil comes from the solenoid via the fuse box and to a load of old sensors.
9th May, 2011 at 10:21:20pm
FIXED |
it was down to a bad 12v supply, i only ever connected it directly to the battery while it was it was being jumpstarted, for some reason now the bat is fully charged it solves the problem, found a good switch live and fanny is you dads brother!
