Home > Wanted > Swap lite steel flywheel inertia for pre engaged
As the title states really, im after a pre engaged starter flywheel if anyone has one that fancies a swap?? Its an ultralite steel one
Regards
Mike
Changing the ring gear is easy enough
As Colin says Mike, just change the ring gear over buddy.
Then it'll balancing again though. Wouldn't it be easier to buy a new one and sell the one you've got? That has got to be cheaper vs. the effort.
Thanks for the relies chaps, yes v your probaby right.
or, just buy an inertia type high torque starter. Even beter *wink*
like the on I got from Wil/Ben's mate *smiley*
