| Home > General Chat > Getting ready for the track | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
6th May, 2011 at 08:03:00am
Hi guys,
6th May, 2011 at 09:12:41am
Oil pressure sounds totally normal to me.
6th May, 2011 at 09:20:20am
I prefer yellow tag master cylinder with no servo personally.
Edited by John on 6th May, 2011. If something is worth doing, it's worth doing half of. |
6th May, 2011 at 09:21:01am
servos are for girls. On 11th Feb, 2015 robert said:
559 Posts Member #: 2775 Post Whore Aberdeen |
6th May, 2011 at 10:05:00am
I ditched the servo on mine for the same reason, felt good on the road but didnt give enough feel on the track |
6th May, 2011 at 01:09:54pm
I like my servo :)
In the 13's at last!.. Just |
6th May, 2011 at 01:21:04pm
but you have girly hair On 11th Feb, 2015 robert said:
6th May, 2011 at 05:37:12pm
those pressure relief ajustable valve after market ones are no good in my book,
1300 Posts Member #: 829 Post Whore essex |
6th May, 2011 at 09:22:00pm
On 6th May, 2011 Alex1340 said: on the brakes pump the brake pedal with the engine switched off and then start the engine with your foot on it and you will feel the pedal move down a little bit this means the servo is working
Hi guys, I've booked a 15min window on track at ppc in the park and in preparation I'm Trying to get a few bug ironed out. First off brakes: I've got a servo and think I'm not getting grate pressure from It also the feel isn't great. Do you think both of these points will be improved by going back to a later style dual master cylinder? Second oil pressure: when I've been driving it around from cold I get mega pressure 80-100psi as the engine warms up pressure drops abit as you would expect to 50-60 but the pressure fluctuates massively with the engine revs when really ho at idle it's down at 20-30 but goes all the way up to 70-80 when I rev it over 4000rpm. Do you think the min pressure ball and spring thingy is playing up?? And are those addjustable things any good? Cheers 1293 Turbo mini
6th May, 2011 at 11:25:34pm
Think I'll dig out the old master cylinde and pedal. Glad the oil pressure sounds normal.
