| Home > Help Needed / General Tech Chat > Lay gear end float | |||||||
7th May, 2011 at 12:32:58pm
Been replacing the bearings and thrusts for the lay gear in the van's new box.
Edited by apbellamy on 7th May, 2011. On 11th Feb, 2015 robert said:
7th May, 2011 at 12:39:01pm
I'll stick my neck out and say it will be OK assuming that you are using straight cut gears.
7th May, 2011 at 12:43:16pm
Thanks Paul. Yes, it's a straight cut gear set.
7th May, 2011 at 12:46:28pm
they dont look that bad to me, I'd use them on a SC box on the basis there will be no loading on them. On 28th Aug, 2011 Kean said:
7th May, 2011 at 01:10:24pm
Use some 0.005" shim steel behind the larger thrust. Works a treat when in need.
Edited by Sprocket on 7th May, 2011. On 26th Oct, 2004 TurboDave16v said:
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
7th May, 2011 at 06:39:46pm
Andy.
7th May, 2011 at 06:52:32pm
On 7th May, 2011 Joe C said:
they dont look that bad to me, I'd use them on a SC box on the basis there will be no loading on them. The pictures are deceptive Joe, there's a deep groove were the bearings have worn into them. I'm not happy that the bearings would be held in tight enough with those thrusts. Richard, PM on the way. Edited by apbellamy on 7th May, 2011. On 11th Feb, 2015 robert said:
7th May, 2011 at 06:56:40pm
The bearings should be enough of a nip in the laygear that the thrusts should only act on the gear endfloat, not the bearing. If in doubt drop a dab of retainer on the bearing outer cage when fitting.
7th May, 2011 at 07:02:44pm
Thanks Tom. New bearings aren't the snuggest fit so will do that. On 11th Feb, 2015 robert said:
9th May, 2011 at 07:39:57am
I'd say 0.010 endfloat is OK with a straight cut box. On 13th Jul, 2012 Ben H said:
9th May, 2011 at 01:26:52pm
that is still 6 thou slop, and a high frequency movement of 6 thou will generate vibration. Vibration saps power and kills bearings quicker.
9th May, 2011 at 01:26:56pm
9th May, 2011 at 01:35:37pm
So good he said it twice LOL!!
9th May, 2011 at 01:36:50pm
Richard has posted us some 0.006" shim steel so I'll slip some of that in behind one of the thrusts ( glued to the tang) and have a cock on 0.004" end float. perfec On 11th Feb, 2015 robert said:
9th May, 2011 at 01:38:14pm
Have you got the thrust we need then Colin? If something is worth doing, it's worth doing half of. |
