Home > Help Needed / General Tech Chat > Extra breather
I have been thinking of drilling and tapping the dizzy blanking plug to fit a union door some extra breathing? Any reason why this is a stupid idea? I don't have they one on the clutch side of my engine.
Thanks for any comments
do it,
put an oil seperator in there though as the crank will chuck a fair bit of oil that way.
Mm will have a think about how I can put a separator in thanks joe
just a canister filled with steel wool should do, it can jsut go in the pipe.
or, you can do what I have done with my transfer breather, I ran it into the rocker cover, and then run one big breather tube (1") to a catch tank.
Like this Joe?
http://cgi.ebay.co.uk/Ford-CVH-Oil-Crankca...c3#ht_699wt_689
Yeah I think so, I think they are just filled with steel wool,
this would do,
http://cgi.ebay.co.uk/Hillman-Imp-crankcas...r-/220764175771
jimmy
Member #: 829
essex
what you can do is go from the dizzy hole to the rocker cover then put breater from the rocker cover so if you get oil up the pipe it will stay in the engine
1293 Turbo mini
Mmm got me thinking
Amp
Member #: 7856
I made this as a dizzy blanking plug, threaded inside incase
a) I need to block it off
b) Incase I need to get a slidehammer on it later on!
Behind is my rocker cover, as Joe said (well I used his idea anyway!) I was planning to run the take-off into the rocker cover and then pipe it off to the catch tank :)
I'm not so sure that there is a requirement for a canister.
Where are you feeding it to?
If you are just taking it to a catch tank then there is no need for a canister. Canisters filled with 'wire wool' are really to stop flame fronts from backfires through the carb getting to the sump.
Presuming that your catchtank is likely to be a reasonable distance from the dizzy hole and maybe above it, this should prevent any slashed oil getting very far.
I'm not sure I see the point of feeding it back to the rocker cover, this will be at a similar pressure to the sump so won't really help breathing at all.
Will, it's to a catch tank, which is on the inner wing and mounted higher, I will get a union a start experimenting....
jimmy
Member #: 829
essex
do you have a return to the sump on the catch tank ?
1293 Turbo mini
you know that you know have to threaten legal action to anyone that copys the bung!
Amp
Member #: 7856
Damn, I knew I forgot something, I mean "I made this dizzy blanking plug©"
It has been specially designed you see, so the extra ridges increase aerodynamics..
Edited by Amp on 8th May, 2011.
the rotational grooves centrefuge the oil from the air! lol
Fortecphil
Member #: 7641
Jersey, CI
At supersonic speed? lol
jimmy
Member #: 829
essex
that will do the job nice work
1293 Turbo mini
well after drilling three holes, tapping two, one heater take-off, some pipe, and clips I ended up with this.... I used the ford filler/breather cap just made the 90 deg easier.. Hopefully it will help..
:thumbs up:
wintersurferuk
Member #: 2208
*Clapping* nice i like it!
jimmy
Member #: 829
essex
looks good
1293 Turbo mini
mini_mad69
Member #: 7048
Bridgend
I copied this idea, Im using the rocker box to catch any oil, which then vents out through the other blue pipe, hopefully it will help crankcase pressure.
Edited by mini_mad69 on 20th May, 2011.
Turbo parts collector at the moment, almost ready.
Nice
