Home > For Sale > Clearing out workshop, needs to go!
Owen
Member #: 6496
Somerset
Circumstances dictate I need to move out of my workshop so need to clear out :(
Weber 45, maniflow 7" steel inlet modded for evacusump, new ITG filter (missing clip annoyingly!), linkage - £300 ono
MED low distortion roller tipped rockers, 1.5:1. Seen about 1500 miles - £215 ono
Bespoke tubular modified front subframe (professionally), powder coated royal blue. Designed for front mount rad, stainless steel heavy duty lower engine steady (adjustable) and bracket - £260 ono
Straight through motorbike exhaust set up, bespoke 2" stainless bend and flange, maniflow cherry bomb link pipe. I was using it with a maniflow stage 2 LCB so will fit whatever bore size that is - £120 ono
Fibreglass bonnet, painted blue and orange, half of two bonnet straps attatched - £10?
Sealey 185 supermig, comes with half a reel of 0.8mm wire, torch and 2 regulators (same as this one http://www.sealey.co.uk/PLPageBuilder.asp?...iredresults=16) - £400.
Most stuff collection only from Bristol (can post smaller stuff).
Will add more stuff as and when I find it.
Owen.
Edited by Owen on 8th May, 2011.
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair
mini_mad69
Member #: 7048
Bridgend
Interested in the fibre bonnet, is it mk1 or mk3? I can collect aswell.
Turbo parts collector at the moment, almost ready.
Got some pics of this subframe?
Owen
Member #: 6496
Somerset
It's started out a mk 3, but I cut the lip off it.
Pics of the frame on the way
Owen
Member #: 6496
Somerset
Edited by Owen on 9th May, 2011.
