Home > For Sale > Shed clearout! Its all gotta go!
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
MPi Rad, almost like new except for 4 rad mounts pushed through gills £45
MPi Tank with pump (no fuel level sender) GWO £70
2 MPi injectors in homemade housing (fits onto HIF manifold) £50 (with braided fuel pipes)
FSE 1.7 ratio powerboost valve as new £40
BC&M alloy inlet manifold £15
Minispares alloy inlet manifold with good HS4 attached £30
SPi front subframe with top and bottom arms in good condition £50
1 piece flipfront (roundnose) and brace bars, never fitted £65
4x 10x5" Revolites (I think) with useable tyres £55 (I think i have the nuts too somewhere)
Pr 8.4" calipers for rebuild £30
12G202 head bog standard £40 (inc valves and springs)
998 A+ short engine £40
A+ gearbox, dont think shes a cruncher £60 (will check FD) x2
1275GT gearbox and gear cluster (dismantled for rebuild) £60 (different 3rd gear ratio so im told??)
998 A (not A+) head £20 (inc valves, springs)
Pair brand new black vinyl high back recliners (Carrelli?) v comfy £190
MPi twin speed heater, both speeds work although will need matrix as its split and I chucked it! £30
Pics on request and no doubt more to be added later!
Edited by eaton_mini on 17th May, 2011.
boldy
Member #: 2464
Weston-Super-Mare
I'd be interested in the HS4 and manifold.
pics of this please?
2 MPi injectors in homemade housing (fits onto HIF manifold) £50 (with pipes)
eaton_mini
Member #: 1649
HS4 and manifold
eaton_mini
Member #: 1649
Injectors and housing. This is on the car and silicon tubes not included! (I have a better pic at home but this gives you some idea)
Edited by eaton_mini on 10th May, 2011.
eaton_mini
Member #: 1649
towners
Member #: 9282
Portsmouth
Interested in revolites where in w.sussex are you?
quinton
Member #: 1911
Ones about seats
eaton_mini
Member #: 1649
Towners, Im Littlehampton
Quiton, pics coming
eaton_mini
Member #: 1649
Seats are vinyl not fabric....
Revos, (laquer is shagged!)
