| Home > Non-Mini Discussion > Machining | |||||||
181 Posts Member #: 9072 Advanced Member Jersey, Channel Islands |
10th May, 2011 at 02:33:16pm
Hi
Edited by fasteddie84 on 10th May, 2011. Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
10th May, 2011 at 02:42:43pm
could you get a machine shop to machine out and fit an insert to suit the correct size of bearing?
10th May, 2011 at 02:47:44pm
I would of thought ford would have used the same hub on other cars? If so your sorted, if not the above sounds like a plan Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
10th May, 2011 at 02:51:05pm
Or maybe you coud do the same as when you get an engine block bored? Take the bearing and get it machined to the same size? Audi s4 b5 - 470bhp & 486ft lbs
10th May, 2011 at 02:54:40pm
just found a car breaking on ebay if its any use |
10th May, 2011 at 02:56:54pm
How loose is the new bearing in the hub? You could glue it in with bearing fit if it is a reasonable fit.
10th May, 2011 at 03:21:48pm
Thanks guys.
10th May, 2011 at 03:23:45pm
If the bearing will drop straight in then it is no good. If it still requires a knock from a hammer or push from a press to get it in then some bearing fit (loctite) will do the job so long as you get both parts clean and thoroughly degreased.
10th May, 2011 at 03:57:17pm
On 10th May, 2011 fasteddie84 said:
Thanks guys. Was going to see if I can get a machine shop to do that. The outer diameter is 59mm and I would say that the hole is now 59.5mm. I was thinking about getting a machine shop to machine out the hole to 61mm and then get them to make up an insert that is 59mm internal diameter and 61mm outer diameter so that it all fits in nicely. I asked Ford to cross check but they couldn't. The bearing was a nightmare to get hold of as the part that the Ford system said was way too big and in the end, they gave me one for a van that looked almost right but turned out to be a nightmare. Even today, they noticed a different screen and it says that you cannot get the bearings and you have to buy a new hub, which you can't get either. Just been on eBay and found 1 4x4 breaking so sent them a text - Thanks Rob Tom - What glue is this and would it work for this gap? All I need it to do is take up the little slack. That idea might sound feasible. But what you are proposing is a 1mm thick bit of pipe, perhaps less. Not something easily machined What type of bearing does it use ? Is it a big single double roller, or a taper style ? Another option may be this spray metal stuff ? Not sure on specifics, but they spray it on to build the metal back up, then machine it down again. 9.85 @ 145mph
10th May, 2011 at 04:06:35pm
I would say at present, there is a 1mm gap in total (0.5mm each side of the bearing).
10th May, 2011 at 04:24:39pm
are they not the same as the mondeo 4x4 Crystal Sound Audio said:
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
10th May, 2011 at 05:17:48pm
maybe replace the hub with 2 new ones from said mondeo 4x4???? "Cars are a lifetime of pain" |
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
11th May, 2011 at 12:07:10am
Looking at it from a different angle so to speak, why not go to a good bearing supplier and see what other sizes are available. http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
