| Home > Beginners Tech > Dim/dip relay | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
12th May, 2011 at 11:33:27am
Not a very exciting one im afraid.
Edited by Simon on 12th May, 2011. |
12th May, 2011 at 11:35:57am
I've joined them together before. But when I upgraded to halogen headlights the switch got very hot. So I scavenged a dim/dip from an old metro. If something is worth doing, it's worth doing half of. |
12th May, 2011 at 11:36:56am
You can certainly do away with it, doesn't really add any useful function IMO. As for whether you can just link it out, you will need to have a glance at the wiring diagram to sort out what is what and ensure everything is still fused relayed etc as needed
1300 Posts Member #: 829 Post Whore essex |
12th May, 2011 at 11:43:22am
yes it is safe not to use 1293 Turbo mini
12th May, 2011 at 11:58:34am
I have got halogens too John, very hot doesnt sound so good. Would that be very hot but safe that I can stick it through an MOT tomorrow and then add a relay another day?
12th May, 2011 at 12:11:13pm
Yeah to be honest I only noticed it got hot when I'd been out for a couple of hours at night. If something is worth doing, it's worth doing half of. |
12th May, 2011 at 12:13:36pm
what size bulbs are you using ? 1293 Turbo mini
12th May, 2011 at 12:23:06pm
Philips H4 12342 60/55W |
12th May, 2011 at 12:26:50pm
std bulbs 1293 Turbo mini
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
12th May, 2011 at 07:21:39pm
I'd fit a relay tbh. Not the dim dip one but one on it's own to power the lights and just use the switch to energise the relay.
12th May, 2011 at 07:59:38pm
On 12th May, 2011 turbominivanman said:
If you go straight through the switch for a long time, it'll eventually get so hot that the copper pins on the back half of the switch will melt their way through the plastic and hey presto ! One night you won't have any lights that happened to me, then the loom melted :( not a nice night my lights bar side are on relays now :) but back on track, if its just to get it through the mot, bodge away
Yes i moved to the darkside |
12th May, 2011 at 09:47:11pm
the power you will use is about 10 amp on your headlights the switch will handle that all day long 1293 Turbo mini
