| Home > Help Needed / General Tech Chat > Intercooler placement | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
13th May, 2011 at 08:40:00am
I had a play around with another intercooler last night and came up with this.
13th May, 2011 at 08:48:50am
I would try and angle it more like / and duct it with a cold air feed Drives
13th May, 2011 at 09:10:47am
Have a look at what Nic and madmk1 have done In the 13's at last!.. Just |
13th May, 2011 at 09:33:57am
are you running megajolt - if so could you not squeeze it down the front? |
![]() 141 Posts Member #: 7891 Advanced Member Annapolis, MD USA |
13th May, 2011 at 11:45:56am
I'm far from an expert on these, but it looks a bit thick to me....would most likely benefit from being in a more direct air flow path. Eric
13th May, 2011 at 11:49:50am
Would be much better in the airflow. If something is worth doing, it's worth doing half of. |
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
13th May, 2011 at 12:17:56pm
it would be better down the front if you can i had mine at 45 degreese and it didnt get enought air in my opinion.
"Tuning should be a compromise between what is possible and what is necessary"
13th May, 2011 at 12:31:36pm
It won't do a lot there as your inner wing will prevent much air flowing through it. As others say, do what you can to get a cooler at the front.
1300 Posts Member #: 829 Post Whore essex |
13th May, 2011 at 12:47:35pm
you need to replace the one you have its a bit larger in size for the room you have or cut the inner wing out and vent the bonnet that side for air flow time you have cut it al about i can get a 2wd cosworth cooler and do what alexb has done http://www.flickr.com/photos/altrezia/5577...157616417623404 Edited by jimmy on 13th May, 2011. 1293 Turbo mini
13th May, 2011 at 01:09:27pm
I know Dan doesn't want to cut holes in his bonnet.
13th May, 2011 at 01:19:42pm
Almichie's TT intercooler looks to fit quite well. If something is worth doing, it's worth doing half of. |
16th May, 2011 at 02:00:37pm
Haven't had time to check back - lots of replies!
16th May, 2011 at 02:20:20pm
Just had a look at markka mini and feel a bit inspired and think if I cut my inner wing and angle the cooler a bit more then direct the airflow in much the same way I might be able to manage something that works.
