Home > Wanted > URGENT :( t piece that screws into turbo :(:(:(
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Oh no, when fitting my speedocable i somehow snapped one of the legs off the little T piece thats joined to the turbo.
Im only using one of the legs anyway for the MBC, the one pointing towards the block is blanked off with a hose + bolt.
What can i do! its bank holidays and im going to miss minis VS beetles :( What would one of you lot do? I can attempt to clog up the offending hole, and use the good leg on the other side? But thats bodging!!!
Cant belive its happened so close to york. Do any of you ahve a spare one to sell that i can buy/replace with you that you can take to york?
Another thing i heard once was that something that comes off the manifold is the same thread? What is it? Something iwth one outlet (leg!)?
Please help me
James
just block the other side up. have it threaded and put a grub screw in. if you dont need it then it doesnt matter!!
jamesfawcett
Member #: 218
Done! Solved it without bodging *happy*
Have you double checked down the spark plug holes for washers?????
*tongue*
