| Home > Show Us Yours! > Pic Request: Intercooler | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
13th May, 2011 at 08:27:19pm
Have any of you guys got some pictures of your cooling setups? Can you show me where you put the rad, intercooler (and if you have one) an oil cooler? As well as how you plumbed it in and where your pipes go.
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
13th May, 2011 at 08:29:18pm
All the info is on this site. But the onus is on you to look for it. More to the point don't try and build the car in your head. Make a start by getting an engine or whatever, and then things will fall into place.
13th May, 2011 at 08:29:42pm
13th May, 2011 at 09:44:08pm
Ahh, very interesting results - I've saved a few piccies for later inspection :)
13th May, 2011 at 09:54:48pm
most commonly used intercoolers are the cosworth 2wd intercooler and escort rs, a few people use the land rover td5 intercooler in the front grill area, or a custom made intercooler such as forge, allard, although these are pricey.
On 15th Mar, 2012 wil_h said:
![]() 514 Posts Member #: 5362 Post Whore wexford in ireland |
13th May, 2011 at 10:46:59pm
i've got a starlet turbo one with the end tanks modified, i'll be doing an update on my picys later in the month, On 5th Jan, 2011 wolfie said:
he floated over to mine for a bit of ring |
![]() 825 Posts Member #: 2208 Post Whore Essex |
13th May, 2011 at 11:12:38pm
I just got the bigest one i could find!
14th May, 2011 at 07:32:38am
No two IC installs in a mini are the same. The search function on here is pretty good. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
