| Home > Help Needed / General Tech Chat > turbo gearbox bearing | |||||||
1300 Posts Member #: 829 Post Whore essex |
15th May, 2011 at 04:27:35pm
will this fit a std gearbox yes or no
1293 Turbo mini
15th May, 2011 at 04:48:59pm
Yes it will, but it won't go into the standard transfer case. On 11th Feb, 2015 robert said:
15th May, 2011 at 05:11:28pm
fuck it 1293 Turbo mini
15th May, 2011 at 05:14:23pm
15th May, 2011 at 05:15:51pm
so as any body got one or can a std one be machine ? 1293 Turbo mini
15th May, 2011 at 05:39:42pm
Why you want one so bad? STD one is up to the job. If something is worth doing, it's worth doing half of. |
15th May, 2011 at 06:34:25pm
because im building a 1380 turbo with a clubman sc gear set xpin diff on a 2.7 FD so a lot on load 1293 Turbo mini
15th May, 2011 at 07:13:15pm
Ask Matt Woods & Nic Rizzardini what nose bearings they run. If something is worth doing, it's worth doing half of. |
15th May, 2011 at 10:09:27pm
so what Torque are we all looking at for std bearing ? 1293 Turbo mini
15th May, 2011 at 10:14:00pm
Pass! Put it this way. With a well build SC box I wouldn't hesitate to put 200nana's through one. (If my engine evers make it that far!) If something is worth doing, it's worth doing half of. |
15th May, 2011 at 11:16:46pm
On 15th May, 2011 jimmy said:
so as any body got one or can a std one be machine ? Nope, not enough meat. On 13th Jul, 2012 Ben H said:
15th May, 2011 at 11:18:37pm
cheers vegard save me looking for hours on the net 1293 Turbo mini
16th May, 2011 at 12:14:44am
I'm sure the casting number on the turbo case is the same as a standard A+ case. I'll have to check for my self. On 26th Oct, 2004 TurboDave16v said:
16th May, 2011 at 02:28:24am
thanks sprocket 1293 Turbo mini
![]() 465 Posts Member #: 1972 Senior Member Worcester |
16th May, 2011 at 07:58:36am
Pretty sure i have a turbo transfer case somewhere with the big nose bearing, i can have a look if your interested PM me |
20th May, 2011 at 11:09:43pm
cheers retoracer 1293 Turbo mini
20th May, 2011 at 11:11:33pm
I thought the turbo and non turbo bearings had the same OD ie the turbo one fits the std transfer case? On 28th Aug, 2011 Kean said:
21st May, 2011 at 01:01:33am
i thought it was a larger bearing in general on the turbo box, making it unique im almost certain my old turbo box had a massive ( in comparison) amount of meat there too Yes i moved to the darkside |
21st May, 2011 at 01:04:39am
hahaha lol look at the reply time :) easily amused tonight it seems Yes i moved to the darkside |
21st May, 2011 at 09:20:06am
On 20th May, 2011 Joe C said:
I thought the turbo and non turbo bearings had the same OD ie the turbo one fits the std transfer case? No, the turbo outer race is significantly bigger.
![]() 94 Posts Member #: 7701 Advanced Member Amsterdam Holland |
28th Jan, 2014 at 09:53:18am
I did a search..couldn't find the exact answers.. so i stick it to this topic..
It's a little car .... eating big money |
