Home > Help Needed / General Tech Chat > 1293 v\'s 998+
almichie
Member #: 2065
I'm having a bit of a thinking moment, and I can't decide which way to go...
I'm not on a budget ad such but I do have a fixed amount to spend every month on mini stuff. I know what I want and that's 200bhp, so I was fixed and settled on a 1293 with benross head phase 2 cam etc etc. I've got an mg 1275 short engine, and the omega 1293 pistons.
However, I also have some +80 flat top 998 pistons! And 2 spare engines...
Now I know which ever way I go I need to rebuild the gearbox, I don't think I'll be able to afford a straight cut gear set but will be able to stretch to the drops. What I'm worried about is gearbox strength with 200bhp!
Do I build the 1293 with fairly standard box, or go for a hyper 998?! Help!
For those that don't know I have all the turbo peripherals from my 998 turbo that's running at the moment.
Thanks
Al
Shaft seems nice and snug
If you want 200nana's go with the 1293. The most i've seen out of a turbo 5 port 998 was just over 150nana's and that was wil & ben's racer.
almichie
Member #: 2065
Well maybe I should have said, I'd be happy with 150bhp as long as the torque is there across the range with the 998...
Obviously there would be a benross head fitted to the 998 if I went that way...
I think you would be pushing pretty hard trying to get 150 from a 998 as a road car.
1275 is 30% bigger, much easier.
Keep up John, we have nearly 180 now.
If you want a drievable car with 200 bananas then large bore is the only way really.
120 to 130 is more like a reasonabe target for a 998.
almichie
Member #: 2065
Thanks Wil, I knew your power was up that way.
Drivability is key, I don't want something that'll be hideous to drive!
1293 it is then!
You no read so very good Wil. I said 5 PORT.
jimmy
Member #: 829
essex
go for the 1293 mate
1293 Turbo mini
BALLS, but watch this space, that engine is due more boost, it will make the 170 I always promised it in Ben's new motor.
Edited for correct quote, durrr, sorry Jimmy!
Edited by wil_h on 18th May, 2011.
jimmy
Member #: 829
essex
balls what is ?
Edited by jimmy on 17th May, 2011.
1293 Turbo mini
