| Home > Wanted > Parts for metro(cat d) | |||||||
26th Mar, 2005 at 10:03:40pm
I have just got a pretty rust free metro g reg 1990,gearbox goosed but engine fine, 9.1cr,maybe turboing it for a bit and then putting engine in mini.Or I may bung a spare 998 out the garage in it
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
29th Mar, 2005 at 11:26:30pm
if you hand paint it black there might be a turbo V5 going unless you want to keep it a 1.3..... |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
30th Mar, 2005 at 12:50:16pm
i've got turbo front roll bar if your interested? |
439 Posts Member #: 275 Senior Member bonie scotland |
30th Mar, 2005 at 06:52:35pm
turbo metro rear anti roll bar link bars are polly bushes |
30th Mar, 2005 at 11:32:54pm
Dan)Is the turbo front anti roll bar larger diametre
31st Mar, 2005 at 12:49:55pm
It was off a turbo, and in the haynes manual it mentions it being a larger diameter but i can check it against a std metro later on if you like |
31st Mar, 2005 at 07:10:27pm
complete anti roll bar, 2 drop links with polly bushes, links witcch fit onto back plate radius arms, olso competion bump stops, hydralastic pump, i use to race a metro can help in lowering it |
31st Mar, 2005 at 07:12:33pm
anti roll bar, early bar is 1mm thiner your better off with a late modell roll bar |
31st Mar, 2005 at 09:33:10pm
just to add my bit.....later metros didn't have front dampers......
1st Apr, 2005 at 09:27:35pm
Been for mot today 2 ball joints and advise 2,so changed the lot.
1st Apr, 2005 at 10:10:46pm
cot mushroom so you have left half inch cut ball to suit chuck springs away, fit bumb stops same as mgb , pm sent |
2nd May, 2005 at 04:50:06pm
SORTED
