Home > Help Needed / General Tech Chat > reground crank
Craigie-B
Member #: 9468
Wootton Bassett
Hi all, im looking to buy a turbo engine soon and it doesn't come with a crank, I was wondering if I bought a "reground" crank or got one and had it "reground" would the standard conrods still fit it? Also how would I go about getting the bearings and the caps for the crank?
Craig :)
jamie@thefatgarage
Member #: 9345
Sheffield
If by asking about caps you mean the block doesn't have it's original matched main bearing caps included I'd consider getting a different block as matching a replacement set of caps to the block is expensive as they would need line boring.
Yes, the bearing size changes at a regrind but the conrod size remains the same. Crank bearings are available at most motor factors, and online. Try google.
what are you getting with the turbo engine if its not got crank and caps?
Craigie-B
Member #: 9468
Wootton Bassett
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=417532
I didnt relise the caps were unique?
Yes both crank main and rod caps are matched.
Craigie-B
Member #: 9468
Wootton Bassett
so buying a new set wouldnt be an option - what do you guys recommend then? Buying a different engine ?
jamie@thefatgarage
Member #: 9345
Sheffield
Yes.
ntm1275
Member #: 9395
You could go for new steel main caps, but they would need to be line bored
New caps and line boring will work out to be very expensive, so it would be cheaper to get a different block which came with the main caps
