Home > Help Needed / General Tech Chat > Engine splutters when going round a left hand bend
longy
Member #: 2727
Bicester
Hey guy, needs some help my standard 998 splutters for a brief moment as im going round a left hand bend, its not instant, but usually just as im leaving the bend.
I wondered if it was a loose connection but that would be pretty instant as soon as i turn in. The fueling has been a little messed up recently due to water in the tank, could it be a fueling issue?
Any thoughts?
1972 998 TURBO SLEEPER
Kean
Member #: 341
aka T2clubby
South Staffs
If it is delayed, I would think it were a fuel issue. Check the fuel reservoir and float?
longy
Member #: 2727
Bicester
I just checked the float chamber and it was full of gunk, so cleaned it out and took it for a spin, but still spluttered, i think im going to need t strip the whole carb down and give it a good clean
look in the tank using a torch you may find the same gunge in there.....look for the strainer in the tank gunged up maybe ?
longy
Member #: 2727
Bicester
Cheers guys, but ive just changed the tank, took the one from my project car and it was clean
As the float was full of gunk, it might be worth whipping the needle and jet out for a quick once over.
Have you check the oil level in the dashpot?
longy
Member #: 2727
Bicester
I checked the oil the last week, was a little low but not too bad. i plan to strip the carb this weekend and give it a clean
Unlikely to be the tank as the float chamber should compensate for any surge or momentary loss of fuel at the pump.
Clean the whole carb up with carb cleaner and set the float as shown in the Haynes.
longy
Member #: 2727
Bicester
thanks guys
CR#
Member #: 1367
Cape Town, South Africa
Im sure I've heard of this problem before. Cant for the life of me remember what it was, could have been on tmf (im talking like 3-4years ago when i still went on there)
what carb is it? if its a hs su with the float bowl to one side isnt this a common problem?
the hif's solved it with the bowl under the jet
since its lh bends , id expect the float to be too high ,and fuel flooding in the carb .
longy
Member #: 2727
Bicester
After giving the float chamber a good clean out and ran it for a while the spluttering seems to have stopped.
