| Home > Help Needed / General Tech Chat > N/A valve sizes when on original centres | |||||||
![]() 539 Posts Member #: 6807 Post Whore York |
21st May, 2011 at 10:49:51am
I'm currently spec'ing a head for a project at univeristy and from the flow calcualtions ive done i have decided to go for a 36mm inlet valve with a 30mm exhaust valve.
21st May, 2011 at 11:34:14am
You can fit upto 37.5 inlet with a 30mm exhaust I seriously doubt it! |
21st May, 2011 at 06:55:42pm
Yes no problems, you can fit a 36-31 combination before any offsetting is needed. |
21st May, 2011 at 07:22:19pm
those were the old Cooper S sizes, 36 x 31 and were prone to crack between the seats, before they whent back to 36 x 30, also 35.6 x29.5 at some stage and later 33x 29.5mm layland set for a margin of saftey for them ............ forced induction compouds the larger sizes for reliability!
22nd May, 2011 at 08:41:57am
The old "S" was 35,6/31. They cracked because the casting was crap. Then they went to 35,6/29,4 and stayed there. The 33,3 inlet was on the inferior models.
