Home > Beginners Tech > front suspension diagram
dobber
Member #: 9466
hi,does anyone know where i can get a front suspension diagram for my 93 mini so i can identify damaged parts i need to replace?
Adam_R
Member #: 1938
near Dundee
I've got a diagram sat here.
I'll grab a picture of it and upload it after my tea for you
dobber
Member #: 9466
cheers bud
There are not a huge amount of parts to it!
Top Arm, Bottom arm, Tie rod, hub, cone, trumpet, damper.
Adam_R
Member #: 1938
near Dundee
hope the above are of use to you
dobber
Member #: 9466
one of the damaged parts on my car is number 7(the ball pin) it was seized on and damaged when removing the nut,where can i buy one and is it best to change the ball joint etc aswell?
AWDmoke
Member #: 713
Western Australia
That is what is commonly referred to as the "lower ball joint"
On 24th Dec, 2008 Nic said:
Part 7 is just one part of the ball joint (although probably the most important one.....)
It should be matched with 6 and 8
The replacement "kit" will be 5, 6, 7, 8, 9, 10 and 11 and will usually include the top ball joint parts too (same except the spring (9) is only used on the bottom) as the kits are usually for one side of the car.
They need assembling with care to get the shim pack right.
dobber
Member #: 9466
best place to buy these parts mate?
Minispares, buy the best quality ones, the cheap motor factor ones really are cheap!
Well MiniSpares would be the most obvious choice
http://www.minispares.com/Product.aspx?ty=...id=35318&title=
but there are plenty of other suppliers that deal with the classic Mini.
You might want to pay a bit more for "genuine" ones rather than the aftermarket copies - search - but that's your choice.
EDIT - Tom types faster than me........
Edited by Rod S on 24th May, 2011.
dobber
Member #: 9466
thanks everyone..dobber
dobber
Member #: 9466
i forgot to ask if there is a specific tool i need to for removing and refitting the ball joints
You will need a deep 1.5" socket to undo the big domed nut- also a torque wrench to put it back as it has to be f....... tight (150 ftlb from memory but do not use this without checking)
Most Mini parts places will have these, they will also fit the flywheel bolt and one in the gearbox too if I remember correctly.
nooo dont do the ball joints to 150 ftlbs :), thats the castle nut on the cv joint
the ball joint domed nut (6) wants to be 75 ftlbs it needs to be shimmed correctly too
Edited by Brett on 24th May, 2011.
Yo-Han
Member #: 3228
North of the Netherlands
Someone one ones told me before assembly he always put's the ball pin in a drill while stuck in the ball pin retainer and use some grinding paste to take out bumps and pits out of the pin retainer so he doesn't have to re-shim the next year...
Should not forget to thoroughly clean the parts before assembly..!
Not sure if that is good practice or result of using chinese parts..
Dazed and Confused....
