Home > Help Needed / General Tech Chat > Radiator positioning when using a kenlowe in the wing
tomkidd
Member #: 1962
Lancaster
How do Gents
I've got hold of a Kenlowe fan for in the wing and was wondering if I should try and fit the radiator as close to the kenlowe as possible (as in touching the inner wing)?
If I do this should I still run the standard fan?
jimmy
Member #: 829
essex
i have a clubman front and i run the std fan on the water pump and the kenlowe too
1293 Turbo mini
I ran 12 months with just kens fan. It struggled to keep cool ESP at speed. I put a two blade on, and left ken to sort the traffic situations out.
Seems to work very well
jimmy
Member #: 829
essex
i also used the 2core rad
1293 Turbo mini
jamz
Member #: 2292
Tool
Herne Bay, kent
my plan is a 2 blade facing a supercool 2 core and a 9inch kenlowe. should be ok. still run the stadnard fan if i was you. i once used no fan on my spi cos it broke and wired the standard aux fan up to get me home and it got super hot. the water pump fan actually does alot on a side mount
cant beat a good blowout.
jimmy
Member #: 829
essex
if you are going with a new 2 core rad and run a kenlowe buy one of these http://www.minispares.com/Product.aspx?ty=...id=34526&title=
1293 Turbo mini
jamz
Member #: 2292
Tool
Herne Bay, kent
ive already got a rad and just using a non kenlowe aux fan on a switch.
tomkidd
Member #: 1962
Lancaster
Cheers guys, I thought I had read somewhere that the standard fan only works under 30mph? My idea originally was to ditch the standard fan and just run a kenlowe...
I'm running a normally aspirated 1380 by the way, but it will be sat for a while as its a hillclimber
Edited by tomkidd on 25th May, 2011.
pot_dan
Member #: 326
bradford, west yorks
I have a kenloe fan but the cars not on the road yet ( hopefully within the next month) my plan is to use it on it's own and if I get problems, just fit the mechanical one aswell. I will let you know how it goes.
http://turbominis.co.uk/car/105/
PaulW
Member #: 373
Leeds
I just turn the engine off while i'm sat in the que waiting to go or there has been an incident on track.
Paul
"I'll get there in the end"
Ducting always makes a positive improvement to any fan setup, the standard water pump fan is ducted to the rad (just about) via the cowling. Sticking some ducting the other side to another fan would help, but dont put the rad too close to the inner wing if you have one, the top bit rubs through and scraps the rad as i found out... :/
pot_dan
Member #: 326
After this heat I have decided I will be using both fans. The car is still not ready just yet but I just can't see the electric fan being that much more efficient than the mechanical one that it will be enough on it's own in traffic.
Just my thoughts.
Dan
