Home > Help Needed / General Tech Chat > vortex generator
dannyj
Member #: 9473
newport south wales
im going to be turboing my mini soon after a t3 rebuild and was wondering if i welded in a vortex generator would there be any diffrence in spool up time or power gain
mcalvert39
Member #: 442
Manchester
what the hell is one of those? Sounds like a flux capacitor.
jamie@thefatgarage
Member #: 9345
Sheffield
No
Utking
Member #: 9342
Southern Norway.
Lol no, if anything at all they would make the spool up slower, and be a air restrictor :)
yes it would just slow things up unless it was the size of a shed
mmm a flux capacitor... where can you get one of those? b2f race industries? will my car run off of an old banana skin, and a coke can?
Johnny
Member #: 6926
Accrington
why dont you test it without one on a rolling road, then fit one and get it tested again the same day if possible. (i dont know what they are)
Utking
Member #: 9342
Southern Norway.
Utking
Member #: 9342
Southern Norway.
The idea is to get the air to swirl in the same direction as the turbo goes, so it doesn't have to do as much job. Essentially just makes it harder for it, it's like going upstream a river with a propelled engine :)
I've seen someone use a mesh in front of turbo, to straighten the air before it gets in though.
evolotion
Member #: 83
Glasgow, Scotland
something you would buy off ebay for sure!
Denis O'Brien.
*Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* *Rofl!* @ will
Edited by Joe C on 24th May, 2011.
jamie@thefatgarage
Member #: 9345
Sheffield
Paint it red, bound to be better..
I think wil has a soft spot forthe 80's
mcalvert39
Member #: 442
Manchester
hahaha thats ace wil.
that thing may work better on an NA engine but i cant see it making any difference on a turbo but you never know.
http://kalecoauto.com/index.php?main_page=...&products_id=28
Edited by Sprocket on 25th May, 2011.
On 24th May, 2011 Utking said:
Our turbo machines use a similar principle, which starts the gas rotating before it enters the eye of the wheel.
Edited by robert on 26th May, 2011.
Didn't know the sprint had had a colour change Wil??
I was just about to say the same thing!
That's interesting. But surely to make the air change direction requires energy, so it needs to save more than it takes to get it turning.
Without proper aero testing I think it would be a bit risky to fit on a car, may actually do more harm than good
Any decent medium/large compressor (and pumps as well) use inlet guide vanes to shape the flow path into the impellor wheel(s).
But I think there is quite a difference between doing the flow shaping right next to the compressor wheel/impellor compared to a mile away down a piece of pipe.
Interesting article here in relation to turbocharger compressors...
http://ww1.cnam.fr/turbomachines-moteurs/p.../pdf/EUROT5.PDF
The 90deg bend straight after won't help things.
Just what I was thinking. But you put it better than I did.
Asphalt
Member #: 1027
Germini, black forrest
Similar system are used in 'dusty' countrys to separate dust from the intake air, sort of a centrifugal pre-filter :)
[X] nail here for new monitor
