| Home > General Chat > Clutch | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
26th May, 2011 at 09:24:01pm
Now I know this subject has been covered many times 8-) and I'm not wanting start speculating on what's best, just wondering if there had been any progress on developing an alternative to the double grey setup, as this appears to be the main achilles heel after the the gearbox http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
27th May, 2011 at 09:04:26am
There is the RTS clutch worth a search on here. It's still a DIY job at the moment but people seem to be having good results. "Tuning should be a compromise between what is possible and what is necessary"
![]() 902 Posts Member #: 111 Post Whore Loughborough |
27th May, 2011 at 09:18:30am
Im sure i read at some point that some company was doing a uprated verto pressure plate now, any one know where it is thats selling them? |
27th May, 2011 at 10:10:15am
the med uprated turbo pressureplate is useless with 120wbhp i had it slipping but thats only one company and was 2-3 years ago "Tuning should be a compromise between what is possible and what is necessary"
27th May, 2011 at 10:13:42am
Uprated pressure plates are worthless with a midly tuned motor, >130bhp, the RTS is the way to go, people been using this with >200bhp for a good few thousand miles. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
27th May, 2011 at 07:16:16pm
Depends on the type of engine Gav is building. I get the impression it might rev to 9krpm, and the Verto is a little heavy. I did mention to Fast Carl about an aluminium Verto flywheel and pressure plate. Who know's what might happen On 26th Oct, 2004 TurboDave16v said:
27th May, 2011 at 07:44:15pm
On 27th May, 2011 Sprocket said:
Depends on the type of engine Gav is building. I get the impression it might rev to 9krpm, and the Verto is a little heavy. I did mention to Fast Carl about an aluminium Verto flywheel and pressure plate. Who know's what might happen ![]() i was going to suggest carl should get on this before one of the "big names" see's the potential. turbo 16v k-series 11.9@118.9 :)
27th May, 2011 at 08:46:49pm
Depends on the type of engine Gav is building. I get the impression it might rev to 9krpm, and the Verto is a little heavy. I did mention to Fast Carl about an aluminium Verto flywheel and pressure plate. Who know's what might happen ![]() i was going to suggest carl should get on this before one of the "big names" see's the potential. Bug names,?? I am the heavyweight when it comes to lightweight,lol |
1083 Posts Member #: 8932 Post Whore |
27th May, 2011 at 09:58:39pm
so what is the preference on a turbo engine, verto or pre verto? |
29th May, 2011 at 07:53:20pm
On 27th May, 2011 george91 said:
so what is the preference on a turbo engine, verto or pre verto? Depends what you want from the engine and whether you want a heavy or light clutch pedal Edited by minimole23 on 29th May, 2011. On 7th Oct, 2010 5haneJ said:
![]() 130 Posts Member #: 9395 Advanced Member |
30th May, 2011 at 12:21:39am
Is there a step by step guide on the RTS
30th May, 2011 at 06:55:56pm
Th don uses one of my aluminum flywheels and TI basckplate with a grey cover, this peadal is unbelievably soft for a grey but never had a problem with slipping, and youv'e all seen the vids
30th May, 2011 at 07:55:44pm
so what is the preference on a turbo engine, verto or pre verto? Depends what you want from the engine and whether you want a heavy or light clutch pedal Mines going to be a weekend and track car so i want it to be nice and free reving, i was swaying towards the pre verto. Mostly because of flywheel choice. Edited by george91 on 30th May, 2011. |
30th May, 2011 at 07:58:56pm
so what is the preference on a turbo engine, verto or pre verto? Depends what you want from the engine and whether you want a heavy or light clutch pedal Mines going to be a weekend and track car so i want it to be nice and free reving, i was swaying towards the pre verto. Mostly because of flywheel choice. I'd probably swing that way as well, just pressure feed the thrust if anything more then an orange diaphram is going to be use. On 7th Oct, 2010 5haneJ said:
30th May, 2011 at 09:22:55pm
so what is the preference on a turbo engine, verto or pre verto? Depends what you want from the engine and whether you want a heavy or light clutch pedal Mines going to be a weekend and track car so i want it to be nice and free reving, i was swaying towards the pre verto. Mostly because of flywheel choice. I'd probably swing that way as well, just pressure feed the thrust if anything more then an orange diaphram is going to be use. Yeah i've read of a lot of a lot of main faliures because of grey diaphragms. I'm not clued up on the pressure fed thrust mod, whats required? Edited by george91 on 30th May, 2011. |
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
1st Jun, 2011 at 11:22:49pm
we havnt had any problems with the good old std issue grey on "pre-verto' light flywheels & steel back-plates, but anything over about 140-150hp we machine the flywheel & make a ring press fit onto the flywheel to move the pivot point for the spring on the flywheel, this way we can get 1200 or 1400lbs of pressure using a Blue,,, yes just using a blue. this keeps peddle pressure down also, but you do loose a small amount of travel. not a problem tho
Edited by MadMatt on 1st Jun, 2011. www.miniman.com.au
2nd Jun, 2011 at 12:24:30am
On 1st Jun, 2011 MadMatt said:
we havnt had any problems with the good old std issue grey on "pre-verto' light flywheels & steel back-plates, but anything over about 140-150hp we machine the flywheel & make a ring press fit onto the flywheel to move the pivot point for the spring on the flywheel, this way we can get 1200 or 1400lbs of pressure using a Blue,,, yes just using a blue. this keeps peddle pressure down also, but you do loose a small amount of travel. not a problem tho Can you explain it in more detail as the pictures are a bit blurry I'm very close to buying and building my engine, but would like to use pre verto for the weight saving, but I'm concerned about the heavy pedal and thrust issue with using a grey plate Was looking at the RTS, but there is no simple instructions on what to do I'm very interested in your idea Edited by ntm1275 on 2nd Jun, 2011. |
2nd Jun, 2011 at 03:52:02pm
Looks quite clever that Matt. If something is worth doing, it's worth doing half of. |
2nd Jun, 2011 at 05:58:44pm
I'd like some more info on the preverto mods too Matt, I can't work out whats going on there. On 28th Aug, 2011 Kean said:
![]() 489 Posts Member #: 9159 Senior Member Devon |
2nd Jun, 2011 at 06:16:49pm
^^ what they said |
3rd Jun, 2011 at 01:25:45am
well, simply put, the pivot point for the spring is moved outward, a steel ring is machined & the flywheel is machined to have the new ring pressed onto it, & now the spring is instantly produces way way tougher clamp pressure.
www.miniman.com.au
if you needed more than 1200-1400lbs clamp that is
