Home > Help Needed / General Tech Chat > Poly Windows group buy how to fit?
Scruffy
Member #: 328
Seaford Rise, South Australia
I cannot seem to make the search function give me what I want! But by now everybody except me must have fitted their PFP windows.
What did you use and where did you buy the fittings? What did work and what didn't please?
I have fitted windows before but wanted to smarten the car up a little hence them being replaced after 15 year hard use - thanks!
On 5th Sep, 2011 Vegard said:
george91
Member #: 8932
So do you have the bolt in windows?
I found this kit, might be worth a look.
http://www.acwmotorsportplastics.co.uk/ind...&products_id=62
http://www.acwmotorsportplastics.co.uk/ind...ndex&cPath=1_62
Edited by george91 on 27th May, 2011.
pickmeup
Member #: 1200
the guys at ACW are really good ive had a lot of stuff of them over the last couple of years
Nick, did you get the standard windows or oversized so you can bolt them in.
Ive bolted mine with countersunt allen heads so there flush with the windows.
Both rear quarter glass's were a tad short and hardley any lip on the car to bolt them in, so i made the lip on the car deeper with an extra strip of steel, problem otherwise is the bolts are right on the end of the window.
rick
Edited by cossierick on 28th May, 2011.
