Home > General Chat > Making Room
carts60
Member #: 9335
Bromley, SE London
Having got my intercooler in the post - an RS Turbo one so not massive, i took a quick look behind the grille, and I knew space was tight, but there's literally no room at all!
What with the starter motor, alternator and a shed load of wiring (i'v got megajolt so i'll be losing the distributor) how does everyone fit their intercoolers behind the grille as well as the piping?
Can i cut out the struts behind the grille to get some extra space?
eden7842
Member #: 8852
leicestershire
ayup dave, look how it sits on turbo-minis 998. Mite do u good. While ur there read the site 10 times if u havent allready, ul learn alot.
george91
Member #: 8932
If you have the 2wd cossie one, most fit them behind the bonnet .
Remove dizzy, use a small alternator, use a smaller (Brise etc) starter motor or rotate the standard one. Then grind any excess from the transfer gear case and chop out the vertical strut on the slam panel.
This will give you shit loads of room.
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
Fit a clubby front, you can have a small beer fridge in the front then too :)
carts60
Member #: 9335
Bromley, SE London
Yeah Eden, i'v seen the 998 before but I'd much prefer to have it sitting behind the grille. Its just looks really messy and un-thought-out otherwise.
Haha. Il believe shit loads of room when i see it. *smiley*
Yeah, the room clubby's have is unreal, but im definitely sticking to a round nose. Beer fridge is a tempting addition though
Maybe shit loads is an exaggeration, but there's enough. Granted, my intercooler still fouls the grille a bit, but you'll have no problem with the little RS one.
carts60
Member #: 9335
Bromley, SE London
Laaavly
