Home > Help Needed / General Tech Chat > HELP please
balla
Member #: 8731
i have been rebuilding my 1310 mg metro turbo engine and on torquing the SECOND to last head stud down :@ the thread ripped out the block :(. what thread is it and what would people suggest
3/8"UNC helicoil
balla
Member #: 8731
would a helicoil be strong enough ?
helicoil will be stronger since it itself has a larger contact with the new threads in the block
If fitted correctly it's actually stronger than the original thread (the tapping in the block is on a slightly larger diameter than the original thread, so can carry more load, and the alloy steel used for the helicoil itself is stronger than the material of the original thread in the block).
But they are not allways fitted correctly, make sure it's done by someone who knows what they are doing.....
EDIT - Sprocket beat me to it.....
Edited by Rod S on 29th May, 2011.
balla
Member #: 8731
cheers second thing where can i get one on a bank holiday weekend lol
*laughing*
Two chances>>
Fat chance
and
No chance
also, you do realise it will need drilling out and tapping for the helicol insert?
Edited by Sprocket on 29th May, 2011.
balla
Member #: 8731
i can get one tuesday when i go back to work but i was hoping to having it running over the weekend
Weekend's gone mate :(
balla
Member #: 8731
yeah but it is bank holiday tomorrow so i ment long weekend lol
balla
Member #: 8731
and yeah i do realise that i have helicoiled things before but i didnt know if it would be strong enough
I thought the same about Helicoils when I first did a head stud, but they really are more than strong enough. Especially on an A series as really you don;t have to torque them THAT tight- I've helicoiled an alloy block Peugeot engine with stretch head bolts that require 20Nm+300 degrees of angle tighten- if anything would test the helicoil that would.
