Home > Help Needed / General Tech Chat > need a bit of body advice
blister
Member #: 2590
Croydon
not been on here in a while, but this morning i started cracking on with the minis body work! And i sadly have a sunroof fitted and am after coverin it up. . . I have a fibreglass roof skin waiting to be fitted but if i fit it am i still allowed to enter hill climbs as i am after entering motor sport at the palace next year
jamie@thefatgarage
Member #: 9345
Sheffield
I had a sunroof and wanted rid of it so I added a fibreglass roof skin over the metal roof. Just cut out the sunroof and stick the fibreglass roof over the top. It works out stronger...
edit:fixed the typo..
Edited by jamie@thefatgarage on 31st May, 2011.
MarkGTT
Member #: 1194
Shropshire.
Depending on the class you want to enter you will need to replace the roof with a steel one.. best to read up on the class requirements before making the decision.
I also wouldn’t suggest sticking a fibreglass roof over the existing roof.. to me its a bit of a bodge.
The car has to remain Steel withinn the axel centres, so no, a GRP roof is ineligable for the classes that you would want to run in.
GRP over the top seems a bodge to me too
It's not that hard to fit a new steel roof skin.
blister
Member #: 2590
Croydon
i was just tryin to dig out the mini world featured that has the article on changin the roof skin, but cannot find it! Is it possible to remove a roof skin from another mini and fit it to another without damaging it?
blister
Member #: 2590
Croydon
Yes, cut the roof of the donor car below the gutters and grind it back the bottom of the lip on the skin. should be fine as long as you are carefull
It is possible, and not difficult at all, as that is what I did. There is plenty of pics in my build thread. *wink*
blister
Member #: 2590
Croydon
that is brill thank you fellas :) now got to look out for another mini lol :) or donor :)
pic's in my build thread. I braced the shell, but this is not necesary
The only thing I would say is leave the front and rear screen in place. I found that the front screen of mine was VERY tight when refitting and it was because the front gutter had rotated slightly. It was easy enough to pull out, but with the screens in place it will prevent it from happening. *wink*
