| Home > Help Needed / General Tech Chat > bleed valve help, still not enough boost | |||||||
11th Jun, 2011 at 11:58:08am
my bleed valve stopped bleeding at 12 psi what would it be? ive got a escort t3 actuator
Edited by eden7842 on 13th Jul, 2011. 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
11th Jun, 2011 at 01:25:29pm
You need a restrictor in the actuator feed.
11th Jun, 2011 at 04:20:34pm
Or use smaller ID pipe. Works on mine.
In the 13's at last!.. Just |
11th Jun, 2011 at 06:14:27pm
would some sort of crimp in the pipe do the job? 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
11th Jun, 2011 at 08:15:48pm
Yes a crimp would work, but it would be difficult to control how big the or small you make it. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
11th Jun, 2011 at 08:37:39pm
use a jubilee clamp. then you can tighten it a bit at a time until it works as you want. On 11th Feb, 2015 robert said:
12th Jun, 2011 at 12:48:47pm
Ok i will try that,
16th Jun, 2011 at 03:59:49pm
should this resrictor make the pipe bore 1.5 mm ?
19th Jun, 2011 at 11:44:06am
so ive tried putting a bike spoke nipple in the feed pipe to the bleed valve and still no more that 12psi,
22nd Jun, 2011 at 08:04:49pm
anyone? please 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
23rd Jun, 2011 at 10:02:00am
Try some more preload. Half a hole is around standard. In the 13's at last!.. Just |
4th Jul, 2011 at 10:59:16am
Before we put a restrictor inline on the van we could only manager 8-9psi. We have found that an old dizzy vac pipe has an OD of 3mm and an ID of 1.5mm. Slots nicely in the vac hose before the bleed valve (we have clamped the pipe down to make sure the bit of hose doesn't slip into the bleed valve) and we can now get 17psi with 1 full turn on the bleed valve. If something is worth doing, it's worth doing half of. |
4th Jul, 2011 at 07:11:40pm
ah well my spoke nipple has done about the same job with no diffrence, i think its my preload, i just havent had time to look at it yet, i will let you know how i get on 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
5th Jul, 2011 at 01:07:17pm
put a narrower restrictor in it pre-avon John boy. 17 psi is not enough On 11th Feb, 2015 robert said:
13th Jul, 2011 at 02:56:21pm
ok so ive checked my preload (all fine) got a tiny restrictor in (1-1.5 mm) ish and still on 12ish psi.
13th Jul, 2011 at 03:05:47pm
As a test you could pull the hose off the actuator and then go for a quick run. Build the boost and see if you can get over 12psi. If so then its down to either your restrictor not being small enough or your bleed valve.
Edited by John on 13th Jul, 2011. If something is worth doing, it's worth doing half of. |
13th Jul, 2011 at 03:51:34pm
thanks john,
13th Jul, 2011 at 04:06:32pm
ok john, been down the road dun what you said and it looks like the actuators not strong enough, its a escort t3 one,
13th Jul, 2011 at 04:28:37pm
get a better actuator cheaply? lol
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
13th Jul, 2011 at 05:19:11pm
Expensive!?
On 13th Jul, 2011 eden7842 said:
ok john, been down the road dun what you said and it looks like the actuators not strong enough, its a escort t3 one, what the best way to get boost now without spending loads of money? cheers Pedro Silva
13th Jul, 2011 at 05:55:26pm
Wind the pre load up and try again.
14th Jul, 2011 at 03:00:29pm
yeah cheap as im going on my hols next week and im skint!
14th Jul, 2011 at 04:51:41pm
more preload has given me 15ish psi so that will do for now. then il find another to give me that extra 5-7 psi
14th Jul, 2011 at 04:57:53pm
14th Jul, 2011 at 08:47:22pm
the good old t3 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
