Home > Help Needed / General Tech Chat > Kenloe fan and inner wings?
pot_dan
Member #: 326
bradford, west yorks
Has anyone fitted. Kenloe fan with inner wings? I have found thread with brace bars but I have inner wings and have cut the bottom out but don't want to cut anymore than I have to. I dident see this Comming it was supposed to be finished and running tonight *frown*
Thanks. Dan
http://turbominis.co.uk/car/105/
NickG
Member #: 7912
Australia oi oi oi!
use a slide Hammer & pull the grills out heaps it will fit & you wont need to chop.
pot_dan
Member #: 326
Thankyou nick I will do this.
Thanks. Dan
pot_dan
Member #: 326
I tried the slide hammer last night and I am not convinced that I could move it enough. So I cut the hole where it needed to be and I will strengthen it but I am not exactly sure how yet as the fan protrudes quite a bit. But clears the wheel ok.
Thanks. Dan
ministef1
Member #: 1791
Cranleigh, surrey
normally, as with the late type minis, they have a hole in but with a lip all around, all my friends have ever done is cut the hole out for the fan and then put the lip in to keep the strengh, not sure if that helps...
"Cars are a lifetime of pain"
pot_dan
Member #: 326
Thanks ministef that was the first part of my plan, to make a lip round the hole and then see if I need to make some kind of brace bar but was concerned about space and I have lent my welder out at the moment.
Thanks. Dan
