Home > Help Needed / General Tech Chat > Pot joints, hardy spicers or MBE driveshaft kit?
Im going to be "hopefully" running a fair bit of power and torque (read as alot all being well! *happy*).
Also going to be running an LSD
What can the pot joints take?
I know the MBE kits are literally unbreakable but that comes at a cost.
If pot joints can take the power if well maintained then thats what ill go for.
*smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
what ever joints match your diff lol
I'd go for pots.. not broken one myself... a few people have but that seems to be when they are shock loaded, such as off road use!
Alex
AlexF
hey, remeber that picture of Wil/Ben H's pot joint?
That were impressive!!!
Anyway, Stop dreaming about your power Iain*laughing*. Pot joints work for almost everyone here I reckon. Anyone know what MW uses? without question he has the most power - and uses it!
Edited by turbodave16v on 31st Mar, 2005.
I don't know anyone who has ever broken a pot joint on tarmac before
Thats what im trying to convince Dan of!
Pot joints it is then, just keep them in tip top condition.
Dave, yeah im dreaming of power but 1 day it will come *wink*
AllanMcD
Member #: 414
Dalbeattie Scotland
Maybe Iain has had a joint of pot thinking he will have enough power to break anything*wink**wink*
http://www.rabdunn.co.uk/
*happy* nope, 1664 does the trick for me, will make me loads of power!!
Never broken a pot joint, including autograss racing giving them plenty of abuse.
If you think about it they are inherently in a better situation as they only have to articulate "up" and "down" whereas the CV joints have to go "up" "down" and steer as well.
Have bust a few cv joints though.....
AllanMcD
Member #: 414
Dalbeattie Scotland
1664 ??????
so which cv's do you use? just using S stuff at the mo for the S brakes. was all new 8k ago and in good nick.
All the "disc" brake type cv joints are the same afaik.
So either cooperS or later mini are the ones to use. The drum type are smaller and more easily broken.
I think from memory the metro ones are the same as well if you have got some kicking about.
Whatever you use just make sure there is no lash in them, and then wash them out and repack with fresh good quality grease.
On 31/03/2005 21:21:48 AllanMcD said:
1664 ??????
Kronenbourg!
mmmmmmmmmmm
I'll be geting wankered on that stuff over the 3rd weekend in July 2005 I reckon...
Thought id let you answer that dave! *happy*
i only thought you could get hardy spicer outputs for a lsd for some reason.
a handy thing to learn today
Nope, you can get what you like *smiley*
HS ones are thicker in the shaft therefore stronger but it seems common opinion that the pot joint ones are up to the job unless grassing/rallying etc.
Dangerous
Member #: 417
Had hardy spice years ago take up more room under car, exhaust clearance was tight with a lcb dunno what it will be like with a turbo pipe
