Home > 998cc > t2 oil return
softlad1988
Member #: 8462
Has any body got any pic of the oil return they are using with a t2 turbo? im struggling to make one that look any good! :(
jamie@thefatgarage
Member #: 9345
Sheffield
It's not a T2, but would work on one.
almichie
Member #: 2065
I used a car air con pipe, I cut it up and re welded it to suit and then made a final connection with a silicone 90 degree of the right size.
If I remember I used a blank plate to the fuel pump hole, drilled it out and welded a straight bit out
then made a 90 at a 45 degree angle from the turbo towards the bit out of the pump plate then linked them with the silicone 90!!
Make sense?!?
Shaft seems nice and snug
Hopefully, I'm making the new drain for our GT17 which is vaugly the same. If it looks OK, I'll post a pic up...
All mine look shit, be they a T2, an IHI RHF 4 or a GT17. all total bollocks, but they all work and no-one can see them!
I've only ever used the pump hole as a return and just weled some bits up for both ends joined by a 90 deg silicon pipe.
Nick
Member #: 154
Midlands
mine looks like shit too, but as wil says it doesnt leak and no-one can see it anyway. Mine joins into the fuel pump hole via a straight silicon joiner.
softlad1988
Member #: 8462
Thanks guys! massive help! Also does anyone have any experience with using vw 1.9tdi intercoolers as i have been given on! It look good to me but im not totally sure what im looking at! :/
Ignore the shitty looking one, that was a failed attempt. I always seem to get it better second time round...
tadge44
Member #: 2500
Buckinghamshire
It looks like you needed to, too !
All day putting it back together and it fooking leaks! Needs welding all the way round the joint on the turbo side. More fun tomorrow!
