Home > Technical Chat > Are Gearbox and transfer casings machined as a pair?
I'm thinking regarding where the idler gear bearings sit and also the input shaft bearing in relation to the first motion roller bearing.
I have a spare gearbox I was planning on rebuilding but don't have the transfer case to go with it, and would like to avoid pulling apart another engine if I can avoid it for a matching idler case and gearbox casing.
jamie@thefatgarage
Member #: 9345
Sheffield
No they aren't.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
To be honest, I wouldn't risk it. Got no reason to defend my comment, but would you use different end caps on con rods? I've always assumed most components are matched sets.
On 19th Jan, 2010 wil_h said:
jamie@thefatgarage
Member #: 9345
Sheffield
To expand on my earlier reply.
You don't swap around end caps on con rods as they are machined as a pair. Gearboxes and transfer cases are not machined as a pair, so you can interchange them.
