Home > Beginners Tech > gt17
just_jack
Member #: 2928
peterborough
guys,
im buying the final bits for my turbo build, i recently took delivery of a gt17. i'm hoping this is the gt17 that is becoming the common sort after upgrade to the t3
on the stamping block type bit it reads, from what i can make out
GT17 made in italy
9172120
452204-10 NC?00113
if that makes any sense to anybody
and finally what sort of i play should i worry about it has a bit of up/down side to side movement, and it feels like there is a little bit of in/out movement, but its that little i dont know if its the turbo moving when i apply a little force
what can you guys advise?
thanks in advance
jack
Jack Jones
sure its not 452204-01 ?
just_jack
Member #: 2928
peterborough
That maybe correct, I'll have to double check tonight, would it be correct if it is?
And, regarding the play am I right in thinking a little bit of side to side is ok but there should be no in out?
Thanks for you help
Jack
Jack Jones
yes that would be correct jack . and also yes , your correct about the play .
just_jack
Member #: 2928
peterborough
Thanks robert
Just read the turbo again and I've got
Gt17 made in Italy
9172123
452204-1 snCG300123
I gave it a little clean and it looks a bit clearer now
I believe it may have been off a 9-5
Jack Jones
Sorry, that's the wrong one. Post it to me and I'll throw it away for you *wink*
just_jack
Member #: 2928
peterborough
Cheers andy, that makes it clearer
Jack Jones
