| Home > Help Needed / General Tech Chat > noise comming from rad side of the car... found the noise | |||||||
![]() 825 Posts Member #: 2208 Post Whore Essex |
5th Jul, 2011 at 11:45:52am
when i start up the car i get an odd noise comming from the waterpump pully or bottom pully. if i rev the car its go's away, its like a rubbing noise. all the bolts are still in the fan and there is clearence between the bottom pully and the bottom rad bracket, the fan seems to be ok as well. there is a small amount of play in the fan but not loads.
Edited by wintersurferuk on 6th Jul, 2011. |
5th Jul, 2011 at 11:47:26am
sorry it looks like ive put my finger over the mic, i'll get another one! |
5th Jul, 2011 at 05:00:05pm
if its a single timing chain my monies on the tensioner has snapped .........espacially if you have been giving it some pastie
5th Jul, 2011 at 05:29:29pm
its a duplex benross. but now you have me thinking, never considered the chain.... :l thanks for your help!
On 5th Jul, 2011 BENROSS said:
if its a single timing chain my monies on the tensioner has snapped .........espacially if you have been giving it some pastie |
5th Jul, 2011 at 05:41:35pm
It has got a tensioner on there too.
In the 13's at last!.. Just |
5th Jul, 2011 at 05:45:39pm
yeah, im sure theres a tensioner in there, theres some play in the belt, not loads. sounds a bit metallic for it to be the belt slipping. and its not the rad catching the pully, ive cheacked that..
On 5th Jul, 2011 theoneeyedlizard said:
It has got a tensioner on there too. Are you sure the belt isn't loose and squealing? |
549 Posts Member #: 5327 Post Whore Dudley, West mids |
5th Jul, 2011 at 07:02:36pm
Did you modify the timing cover case for a duplex set up. Also did you counter sink the two bottom holes on the back plate? |
5th Jul, 2011 at 07:04:10pm
I had this..took me ages to figure out it was the inside of the bottom pulley just touching the timing cover in one place. Made a sort of dull knocking sound. Mine is a belt drive, but it might be worth looking at. |
5th Jul, 2011 at 07:06:24pm
I agree with Jamie,
5th Jul, 2011 at 08:06:19pm
On 5th Jul, 2011 jamie@thefatgarage said:
I had this..took me ages to figure out it was the inside of the bottom pulley just touching the timing cover in one place. Made a sort of dull knocking sound. Mine is a belt drive, but it might be worth looking at. i had that too
Yes i moved to the darkside |
5th Jul, 2011 at 09:26:50pm
thanks for all the help, i'll have a look tomo. im going to start with the bottom pully and see if it is touching the timing cover, hop thats a fix. if not.... off it comes :(
1300 Posts Member #: 829 Post Whore essex |
6th Jul, 2011 at 08:04:15am
run it up with out the belt on before you start taking rads and pulleys off 1293 Turbo mini
6th Jul, 2011 at 11:43:56am
WINNER!!
I had this..took me ages to figure out it was the inside of the bottom pulley just touching the timing cover in one place. Made a sort of dull knocking sound. Mine is a belt drive, but it might be worth looking at. i had that too ![]() |
6th Jul, 2011 at 11:51:03am
It looks like you might be able to bend it a bit as it only seems to touch on the outer edge. You'll need to make sure the pulley bolt is still tight too, as if you tightened it while the pulley was touching the cover it might not be correctly torqued. |
6th Jul, 2011 at 12:07:01pm
this is what im worried about, it came losse before. so when i changed the pulley i torqued it up to about 180lbs+ ish with loads of locktight, i hate the setup ive got, its shit! when ive got the money ill get a fenton on there.
6th Jul, 2011 at 12:20:57pm
On the same topic. What purpose does that piece of steel that in your case is catching serve? Mine caught badly on my build so i completely removed it. I was running a belt drive set up but have reverted back to a duplex and original cover and now have loads of room. |
6th Jul, 2011 at 12:23:05pm
To do it properly the pulley needs to come off, drill three peened over rivets out, then that useless tin cover will come off to be stamped upon and thrown in the bin.
6th Jul, 2011 at 12:32:21pm
Stick a grinder in there while the car is running?
![]() 514 Posts Member #: 5362 Post Whore wexford in ireland |
6th Jul, 2011 at 12:35:41pm
how good are ya with a hammer and sharp chisel???? thats what i did with mine On 5th Jan, 2011 wolfie said:
he floated over to mine for a bit of ring |
6th Jul, 2011 at 01:24:43pm
On 6th Jul, 2011 theoneeyedlizard said:
Stick a grinder in there while the car is running? On 28th Aug, 2011 Kean said:
6th Jul, 2011 at 01:26:59pm
thanks Tom, when it comes off im going to be doing that all right and then give it to gary to grind till his harts content!
Stick a grinder in there while the car is running? thats your answer to everythin theses days! |
6th Jul, 2011 at 01:27:37pm
i'll try giving it some wackage before! |
6th Jul, 2011 at 04:22:12pm
easy fix sorted!
